I'm just curious, is anyone out there doing it? Or maybe I should start with: does anyone even make one?
Any cabrio guys running a harness bar?
Tags: None
I thought about this before, I think it would be easily to make, and very structurally sound. If you weld the two seat belt guild on the top with a bar running across. and bolt down to the seat belt bolts on the bottom.
It would be a bolt on application. just need to find someone that can make it. I'm sure it would provide chassis flex ridgiidty as well. -
this is what I'm thinking. I want it removable and as non-intrusive as possible. I do have people in the backs seats on a fairly regular basis, so they need to be usable without eliminating the footwells or preventing people from being able to easily get in/out. But I am giddy at the possibilities of chassis stiffening :) :) :)Comment
the seat belt guide is a perfect location. Weld two plates on there, and a bar bolt on similar to the strut bar. It definitely can work. If you take the panel out in the rear you can unbolt the seat belt guide and you can see that its a really thick gauge metal going into the chassis reinforcement place. I'm 100% sure it would work... but who would do it? and where to do it? all questions to be answered.this is what I'm thinking. I want it removable and as non-intrusive as possible. I do have people in the backs seats on a fairly regular basis, so they need to be usable without eliminating the footwells or preventing people from being able to easily get in/out. But I am giddy at the possibilities of chassis stiffening :) :) :)Comment
can you leverage the receptor hole for the Hard top? Its covered by the black rubber plug located right in front of the spring loaded flap.Comment
