REALOEM Question
    REALOEM Question
    Hey guys, quick question. I posted the serial number of an e30 I'm thinking about buying (I miss my old one :() in a vin decode thread on another forum but haven't gotten a response yet.
    So I plugged it into REALOEM. When I went to the rear axle section, it showed the LSD, and not an open diff.
    Is this a reliable way of telling if it has the LSD?
    Thanks in advance,
    -Eric
    Eric Austin
    1990 325i Sterling Silver
    ///M3 CABs | ///M3 strut bearings | Bavarian Autosport springs | UUC Race Shifter | UUC Clutch Stop
    If you have an LSD, it will have an S stamped on it.
      I know, but I haven't bought the car yet, and I don't feel like crawling through the mud where it's parked to find out.
      Eric Austin
        Burn out!
        You can jack up the rear and spin one tire, if they go the same way it's lsd, open will go opposite way. As stated there is an s stamp on lsd models, there is also a steel tag bolted onto the cover that will say the ratio and if it is lsd or not.
          I know that too, but this is a barn find if you will. It's in about 4 inches of mud on a farm in SE Minnesota. Might be cow shit too, I'm not about to find out. Point is, I can't really get under it or jack it up.
          Here's a thought, does someone have a non-LSD e30 that they could punch the serial number in and see if shows the LSD or an open diff?
          Eric Austin
            an lsd was an option on e30's and i don't think realoem is smart enough to know which ones had that option. i wouldn't trust it. just wait and get your vin decoded. mine came back pretty fast when i did mine. maybe try it again. good luck
              if you punch in the last 7 digits into the etk it will tell you specifics for that particular car. so yes. it will tell you
              sales@blunttech.com
              www.blunttech.com
              Like us on Facebook
                LSD's were standard on a few models, if it wasn't swapped out, and realoem says it has one, it has one.
                  Thanks Blunt, that was exactly what I needed to know!
                  Eric Austin
                    if you go to any dealer with the vin
                    you can ask them to print out the original spec sheet from your car
                    it will also list any recalls its ever been in for
                    88 325ic ~~~> Rusty and ugly
                    85 E ~~~> RIP
                      You posted something that was actually helpful! OMG! :)
                      Paypal: vdang5@gmail.com
                      Delta Auto Care
                      2875-C Towerview Road
                      Herndon, VA
                      703.435.1375
                      My Feedback Thread: Evil_Twin
                        Does the phrase "let sleeping dragons lie" mean anything to you?
                        You do know that Blunt has more BMW knowledge in his left nut than you have in your entire body, right?
                        Eric Austin
