Euro clock owners - what was your reason for going from an OBC to clock?
  • Cobra Jet
    • Apr 2008
    • 278
    I'm just curious as to why some folks go ape shit for the E30 "Euro Clock" that fits in the hole where the 6 or 13 button OBC is normally located. If you are one of the folks who has changed over from an OBC to a clock - why did you do the swap?
    My current 6-button OBC has the common bleeding LCD screen, so it's useless (it's also the 2nd 6-button OBC, original went bad as well). I do have a 13-button OBC in excellent shape to replace the bad 6-button - but have been seeing many threads w/ folks selling the "Euro Clock" (and threads w/ pics of E30's having the Euro Clock installed).
    I've thought about possibly going the same route - but here's my reasons:
    1) I hardly use the 6-button OBC as it is, even though it's hardly functional to begin with.... LOL
    2) I don't know that I would actually totally use the 13-button OBC (or all of it's features) once the bad 6-button OBC is replaced...
    3) I don't want to replace OBC's every so many months or years due the LCD screen leaking out which results in a "puddle" instead of anything functional...
    So...... anyone? :pimp:
  • Holland
    • Nov 2008
    • 7178
    I replaced my digital clock for analog. no OBC.
    Originally posted by DEV0 E30
    • ZM Blue Devil
      • Dec 2006
      • 13836
      I usually put in cars that come with 6 button as 6 button pretty useless. Clock is simple and looks cool. Retro fitting a 13 into a 6 is possible but a pain and who really uses it to full extend anyway?
      Levent
      %20levent@gutenparts.com
      Ladies:
      • Stu
        • 4083
        If I had a full 13-button I'd keep that. I'm swapping out my 6-button because I don't really need the temperature gauge. If I had an early 318i with just the clock I'd also swap for an analog. Like Levent said, they are simple and look cool.
        • erik325i
          • Jan 2005
          • 3567
          The OBC is ugly. I also don't use the features of the obc.
          The analog clock is simple, clean, and classy.
          • James Crivellone
            Head Janitor
            • 6304
            I prefer nothing at all
            • fleece johnson
              • Jan 2008
              • 121
              +1
              I may also add the word elegant because I'll probably never get a chance to use it again.
              • e304lyfe
                • 807
                It is not too bad/complicated to install a 13 button.... I have never had the motivation though. In fact, never had the motivation to even fix any of them when they are busted. ........a lot of other things to worry about that are more important then a dumb clock.
                • der affe
                  Technical
                  • Dec 2005
                  • 8452
                  when it would get hot, my 6 button would warp and do weird shit (scramble the screen) unless i pushed on it, then it would be fine. i would park the car for a bit. then when i came back out to it......scrambed screen again.
                  i just got tired of it and all i ever used it for was the clock anyways.
                  i bought a clock off of e30tech for $5 shipped.I went to the wreckers and found a digi clock and harness for $1. when i pulled the cluster to swap in the KM speedo, i painted the needles for the clock and speedo red and installed both.
                  mine does seem to run slow though. i have to bump it up once a month to keep it correct though. maybe it runs on "euro time"?
                  anyone else's run a little slower & loose time?
                  • booostit
                    • Jul 2009
                    • 224
                    had the exact same thing happen to my 6 button
                    • Japandrew73
                      • 2164
                      same
                      • Bishop
                        • 4913
                        Mine too.... just recently though... Runs like jargain all over the screen, till i push on it, then normal.... Is the clock easy to swap? I don't use the OBC and it's crapping out anyway
                        PM me for detailing services in the Longmont / Boulder Area in Colorado!
                        Originally posted by DTM190
                        "fuck the kangaroo dude, his toilet water swirls the wrong way anyway, plus i never liked crocodile dundee or Steve Irwin and vegemite tastes like shit"
                        • selturk
                          • Dec 2008
                          • 1197
                          Euroclock looks cooler.. I have one came from Spain but I don't have the harness to connect it.
                          • der affe
                            Technical
                            • Dec 2005
                            • 8452
                            digi clock and power mirror are the same harness as the euro clock
                            • Lance Racing
                              • Jul 2005
                              • 2340
                              Analog clock is also very easy to reset to correct time.
                              Lance Richert '88 M3, #35 PRO3, i3 etc.
                              www.LanceRichertArchitect.com
                              2019 E30 Picnic Weekend: June 22-23 2019
