Tucked DBs - How to avoid the gap between bumper and moulding?
  • txtorquemade
    • 1758
    You guys that tuck the DBs....how do you avoid a gap between the bumper and the black moulding? Some Ive seen tucked dont have the gap, so it seems and others do. I really dont like the gap, it looks unfinished.
    Is there some trick, or something you can use to fill the gap?
    Any idea would be appreciated. Im buying a 87 325is and might tuck. But not if its going to leave a gap.
    Thanks.... you guys rock.
    sigpic 1987 325is
  • Aptyp
    • 6584
    you need to grind down your molding... tucked in bumper touches molding underneath and that's what causing molding to come up.
    • txtorquemade
      • 1758
      Aptyp...thanks, but I guess I have to look at it to understand that. Any pics or DIY on this anywhere.
      OK OK ...ILL search.. later.
      sigpic 1987 325is
      • delatlanta1281
        Dart Master
        • Mar 2006
        • 10317
        Too much tuck looks retarted. Get yourself some plastic bumper shocks, bolt those to your DBs, and call it a day.
        Yours truly,
        Rich
        you kids get off my lawn.....
        • txtorquemade
          • 1758
          I assume you mean to replace the stock bumper shocks with plastic bumper shocks? If IM going to do all that wouldnt it be just as easy to do a plastic bumper swap? Have to remove the DBs ... to do that right?
          sigpic 1987 325is
          • Leaf
            • Apr 2009
            • 985
            Plastic bumper swap can be some big $$$$$. The shocks you can get pretty cheap if you know where to look.
            • Aptyp
              • 6584
              i have shocks and brackets for plastic bumpers. Eventually I'll find bumpers :)
              ... and sell them
              • Stephen
                Шлем ишака
                • 10774
                Ive got some 88 shocks, for a mild tuck.
                • StereoInstaller1
                  GAS
                  • 22679
                  Just don't tuck 100%, then shoot lag bolts into the bumper shocks.
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • funcrew
                    • Jun 2007
                    • 1223
                    I painted my DB's black and tucked them - I think they looked better stock.
                    "If the sky were to fall tomorrow, the tall would die first."
                    -Dr. Paul Forrester
                    Do I LOOK like I need a psychological evaluation???
                    • ethree
                      • Aug 2007
                      • 1213
                      I took the shrouds off and went with maximum tuckage, it looks alright on the front and very unfinished on the back.
                      • E30Kaiser
                        • Mar 2008
                        • 1790
                        ... and sell them
                        How about you just sell me the shocks and brackets and we call it done? :P
                        "We're not here for a long time, we're here for a good time"-Colin McCrae
                        • E30 Cabrio
                          • Oct 2006
                          • 1954
                          If you have black shrouds and not painted body colored ones, a bit of heat applied to them will help them "wrap" around the bumper but you need to be careful as too much heat will damage them.
                          Bumper shocks from a vert should also work for a partial tuck.
                          1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
                          Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
                          Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
                          • NJGreenBudd
                            • Aug 2009
                            • 121
                            I did the tuck the other day on the front and was not pleased with the result. I actually untucked the shocks and bolted them back in their original length. Just didn't look good, mostly because of the gap between the bumper and trim. Quite a disappointment after getting sprayed with that nasty oil too. Might give it another shot after reading some of this but probably not.
                            '87 325e
                            • straight6pwr
                              • Sep 2004
                              • 3450
                              moldings can be tweaked to fit better. just play with their alignment before tightening down the bolts. the front works pretty well on its own, the back needs some finesse. i could tell you exactly what i did, but making you figure it out is better.
                              no gaps(except where the moldings are wavy), bumpers fully tucked:
