What should I do here...
My new E30's temp gauge isn't working. PO said the sender is new, I put an ohm meter on it and got lower and lower resistance as it heated up, so from what I've read on here that means it's working correctly. I also attempted to ground both wires out and although I'm not sure I ever found a real good grounding spot, the gauge never pinned in the red. SI board batteries were also replaced per PO, but the tach works so I don't think that's causing any issues anyways.
I'm guessing I should go for an Autometer or something, but I'm not sure how that works with the stock sender, if it can even work with it.
TIA.
TIA.
