Suspensions OverHaul...Little CheckList.
  • bimmer_E30
    • 5001
    Ok I really need to do some Front Suspesnsion work over the winter on my E30 Vert. So there goes the list, Remind me if i am missing somthing.
    Front+rear wheel bearings
    Adjustable Camber plates
    New Steering Rack(ABS)
    Control Arm(right+left Side)
    Eibach Pro-Plus Kit - set of 4 Pro-Kit Springs + Front & Rear Swaybar Kit
    sway bars link
    tie rods end
    what else i am missing? i have an after market shocks and they're in perfect shape...so i am not upgrading the shocks.
    Thanks...along i am doing a mini tune-up kit and replacing my exhaust system.
    Originally posted by e30e
  • Wishno87
    • 6025
    Control arm bushings
    Rear shock mounts
    • bimmer_E30
      • 5001
      i am putting new control arms in...i am guessing they will come with the bushings installed already?
      also to add i have a bad Balljoint so that's why i am replacing the whole control arm(s) it self.
      • Wishno87
        • 6025
        control arms and CABs are two different parts.
        • bimmer_E30
          • 5001
          oh shit now i seee...well thats getting repalced i guess...because the rubber on mine is all cracked!
          • naplesE30
            • Nov 2007
            • 1841
            tie rod ends
            • 3bvert
              • 1032
              with everything else your doing, the offset cab bushings are what you want
              • namsayin
                • 1568
                TH Racing CAB
                new RTAB
                subframe bushings
                diff bushing
                you gotta refresh it all man! its better to do everything while its out
                namsayin?!
                • maniacmatt
                  • Feb 2007
                  • 483
                  Why do all this work if you are selling the car?
                  Find great deals on new and used cars and trucks with Kijiji Autos: thousands of great cars for city driving, families, luxury, fun and more!
                  • Emre
                    • Sep 2007
                    • 1228
                    Any particular reason you're insisting on the Eibach kit? There are other springs that are MUCH better on the street. And there are other springs that are MUCH better on the track.
                    1987 Mercedes 190E 2.3-16: Vintage Racer
                    2010 BMW (E90) 335xi sedan: Grocery Getter
                    • 3bvert
                      • 1032
                      Originally posted by namsayin
                      TH Racing CAB
                      new RTAB
                      subframe bushings
                      diff bushing
                      namsayin?!
                      I agree, if you can afford it , do the back end now too, your not looking at a ton of money or time
                      and then you can get a 4 wheel alignment and all will be good
                      • bimmer_E30
                        • 5001
                        TH Racing CAB
                        new RTAB
                        subframe bushings
                        diff bushing
                        namsayin?!
                        actiually since i am swaping a 4.10LSD this winter, i am getting the diff bushing replaced too.
                        I asked and no body gave me a good answer, and i don't really wanna be to low because roads here are shitty.
                        also once i am done with all what i ahave listed i will probably get the X-brace kit from ejnight.
                        i checked the subfarm bushings and they look fine to me....also don't forget that i have a bunch of other stuff that i am buying too...Wheels+tires, MHW tails, Exhaust, Mark D chip etccc
                        • Wh33lhop
                          • 11705
                          That's what I was going to say. Stay away from Eibachs for these cars.
                          paint sucks
                          • bimmer_E30
                            • 5001
                            i have a vert...and there is nothing outhere that will give a perfect drop other than coils...which is to harsh for me.
                            • Wh33lhop
                              • 11705
                              So, why Eibachs?
                              paint sucks
