What to look for when buying
    Im about to pick up an M50, but the owner said it has a blown headgasket. Id like to know if there are any other major parts (pistons, valves etc.) that may need to fixed since the car was driven after gasket broke. Whats the worst case scenerio here? Price?
    - " Ill Never again argue with an idiot. They bring you down to their level and try to beat you with experience."
    http://www.flickr.com/photos/13617577@N04/
    bump because 25 people dont Know
      The head could be cracked.
        A piston ring could have melted.
        I just hate everyone.
        No need for discretion.
          If it was driven a long time after it broke, could have over heated and cause some internal melting down. rings, pistons or a number of other things.
            Thanks, If it still drives does that rule out welded rings? They said it smokes, is that solid signs of a cracked head? Not being able to know for sure, what are some numbers you guys would offer for something like this?
              there is no way to know anything for sure without puzlling it apart. the bottom end bearings could be shot too-- kinda unlikely but possible if there was enough coolant in the oil for long enough.-- i would be pretty sure its just a bad headgasket-- but it all depends how long and what temps the motor was run at.-- head could be warped too-- would just neeed to be milled though to fix that.
