M42 engine fan???
  • loprofile925
    • Mar 2008
    • 27
    M42 engine fan???
    Can anyone tell me how to remove the fan? Im unsure how to remove it because im trying to get the water pump out, if anyone can help id appreciate it thanks
  • GrahamH
    • 66
    A big wrench works quite well. I just bought the right size at sears when i had to do mine.
    • loprofile925
      • Mar 2008
      • 27
      i have a wrench the problem is when i go to turn the nut everything spins!how do i get it to stay still while i turn the nut? sorry but new to this project. thanks
      • Adrian_Visser
        • Jun 2006
        • 2823
        It's a LH threaded nut! if you are willing to spend the money you can buy a special fan clutch wrench which is super thin and can get in between the waterpump pully and the back of the fan, i don know what size it is off hand though iirc the m20 one is 37mm.
        '89 Alpine S52 with goodies
        • GrahamH
          • 66
          Put it in gear. Make sure you're turning it the right way. I dont remember if its reverse threaded or not, but i think it is. Dont worry about it, im an idiot too.
          • FredK
            • 14761
            It's 32mm, just like the M20 fan nut. It's not 37mm. You must turn it towards the driver's side of the car.
            • loprofile925
              • Mar 2008
              • 27
              i loosend the pulled already managed to get unbolted from the hub. so its pretty much just floating on the fan shaft. so if i use a 32 mm wrench what do i do to hold everything else still cause when i go to turn it everythang spins lol what am i missing here alittle confused and yes its probably pretyy obviouse but im blind haha thanks
              • arch4ngel
                • Dec 2008
                • 791
                Hit it with a bfh, towards the driver side of the car.
                I use a metal mallet, the rubber one didn't do the trick for me last time.
                You might have to reinstall the belt temporarily to give it more resistance.
                And as mentioned above, it is a 32mm if the same as the m20.
                EDIT: you can get them on ebay for pretty cheap, the bav auto one is a ripoff.
                Project
                Feedback
                • loprofile925
                  • Mar 2008
                  • 27
                  so basicly i need the pulley hooked back up to have something to hold on to so i can turn the nut?
                  • loprofile925
                    • Mar 2008
                    • 27
                    ok got all screws out but one. now its a weir nut with a whole in it. what kind of tool do i need to remove it? alan wrench or what let me know thanks
                    • loprofile925
                      • Mar 2008
                      • 27
                      now there a was a bolt that took an allan wrench and now that is stripped out help!!!! how do i get that damn allan bold out now?
                      • naplesE30
                        • Nov 2007
                        • 1840
                        check on m42club.com I think there may be a diy on there
                        • TexasTerp
                          • Jan 2009
                          • 3541
                          fan clutch removal tool, rent it at autozone
                          stephenbrody.com
