Free Gas
  • blck325is
    • Apr 2006
    • 1749
    Free Gas
    Stuck in Loma Linda with no tools and 1 bar of cellphone life with a car that is having fuel issues...again. Also with no people to call, seeing as how everyone is in LA or further. I also have a battery pack that is quite dead as well as a dead battery as a result of trying to get the car to start. So should someone take time to come help me out with their tools atleast and some expertise to get me going I will help you out with some gas, and a meal at in-out.. (Oh yeah havent eaten today either) Keep in mind I am a college student and don't have AAA, but will now invest as I have seen it is neccessary. Thanks.
    Originally posted by csermonet47
    Vlad, you are handling this quite unprofessionally.
    Also, you are a cock with tacky taste.
    That is all.
  • george graves
    • 19996
    bump for you my friend.
    Originally posted by Matt-B
    • selturk
      • Dec 2008
      • 1197
      someone help this guy out..
      • blck325is
        • Apr 2006
        • 1749
        Thanks Mr.Graves... it's been a long 2 days. I honestly just wanna rig it to get home somehow.
        That is all.
        • Vethen
          • Aug 2009
          • 186
          Bump, wish i could help.
          ///B///M///W///
          • dannyyisntt
            • 3141
            i'd give ya a hand man, but i'm on the other side of the country....
            • blck325is
              • Apr 2006
              • 1749
              Thanks to all, common socal people....
              That is all.
              • selturk
                • Dec 2008
                • 1197
                ask people around for help and try to push start the car.
                • blck325is
                  • Apr 2006
                  • 1749
                  I tried to jump it with the battery pack until it went dead. It was cranking hard but nothing happened.
                  That is all.
                  • george graves
                    • 19996
                    did ya check the fuel pump fuse/relay?
                    • blck325is
                      • Apr 2006
                      • 1749
                      Yup got a new one today. Still nothing. Got a ride from a friend to the car but he has now vanished.. which is code for "girlfriend called"
                      That is all.
                      • george graves
                        • 19996
                        is the pump turning on when you switch to #2 ignition?
                        • blck325is
                          • Apr 2006
                          • 1749
                          I think it is. I have it hard wired so I turned the ignition on and when I tapped the wire to one of the live wires under the ignition I heard it click on. Not the best way to test it but without tools....
                          That is all.
                          • selturk
                            • Dec 2008
                            • 1197
                            I'm sure you can push start the car.. get few people to push the car.
                            1. Turn off all accessories (radio, wipers, lamps).
                            2. Turn the key to the "on" position.
                            3. Depress the clutch pedal with your foot.
                            4. Put the transmission in first or second gear.
                            5. Release the hand brake and the foot brake.
                            6. Note that the people pushing need to get the car rolling as fast as they can. This works best down a hill or an incline.
                            7. Release the clutch pedal while giving the engine a little gas with the gas pedal once the car is moving about as fast as you can run. The engine should start.
                            source: eHow
                            • george graves
                              • 19996
                              - Gas in tank? (should "slosh" when you bounce the car.)
                              - think about whacking the fuel pump with a wrench - it might be bound up.
