H2oi Problems...
  • dager325
    • Nov 2007
    • 185
    H2oi Problems...
    Down at H2o right now. My 87 325 2.7i was running rough on the way down. If you would push down on the wiring harness it would shut off. Then you could pull up on it and it would run fine. Now it won't start at all. Going to rip the cover off the harness, my dad thinks one of the wires is spilt. Anyone have any other suggestions??? HELP???
  • dager325
    • Nov 2007
    • 185
    It cranks over it just won't start.
    • der affe
      Technical
      • Dec 2005
      • 8452
      that sounds right. have fun finding the wire. what part of the harness is it at?
      • dager325
        • Nov 2007
        • 185
        Right under the intake.
        • blunttech
          • 12850
          maybe the injector harness is all corroded up?? unplug it and see if you can get a look in there. they collect water and get fucked up
          sales@blunttech.com
          www.blunttech.com
          Like us on Facebook
          • der affe
            Technical
            • Dec 2005
            • 8452
            after that ty wiggling each cluster of wires in there, then cranking the car over to see if it starts after each attempt. that will at least help you narrow it down to find the angry wire
            • dager325
              • Nov 2007
              • 185
              It ended up being the fuel pump relay...IDK
              • SamE30e
                • Sep 2007
                • 4319
                I had that problem before.
                1985 325e 2.8 Turbo VEMS
                • craz azn
                  • 745
                  +1. Only time the e30 left me stranded :(
                  Rippin' Proper | Youtube | Vimeo |
