The vehicle identification number you submitted has been analyzed and summary information on your car is shown below.
Report Run Date: 12/07/2004
Vehicle Description: WBAHC2318LGB22627
TitleCheck: No Record Found
Problem Check: No Record Found
Odometer Check: Record(s) Found
Vehicle Information: Record(s) Found
Full History: Record(s) Found
Vehicle Description | TitleCheck | ProblemCheck | OdometerCheck | Vehicle Information | Full History
VIN: WBAHC2318LGB22627
Year: 1990
Make: BMW
Model: 5-Series 525i
Style/Body: 4 Door Sedan
Engine: 2.5L I-6 EFI SOHC
Country of Assembly: Germany
Your Vehicle Checks Out! AutoCheck's database for this 1990 BMW 5-Series 525i (WBAHC2318LGB22627) show no significant Title events. When found, events often indicate past automotive damage or warnings associated with the vehicle title.
Problems Checked Results Found
Abandoned No Abandoned Record Found
Damaged No Damaged Record Found
Fire Damage No Fire Damage Record Found
Grey Market No Grey Market Record Found
Hail Damage No Hail Damage Record Found
Insurance Loss No Insurance Loss Record Found
Junk No Junk Record Found
Rebuilt/Rebuildable No Rebuilt/Rebuildable Record Found
Salvage No Salvage Record Found
Your Vehicle Checks Out! AutoCheck's database for this 1990 BMW 5-Series 525i (WBAHC2318LGB22627) shows no historical events that indicate a significant automotive problem. These problems can indicate previous car damage, theft, or other significant problem.
NHTSA Crash Test Vehicle No NHTSA Crash Test Record Found
Frame Damage No Frame Damage Record Found
Major Damage Incident No Major Damage Record Found
Manufacturer Buyback/Lemon No Manufacturer Buyback/Lemon Record Found
Odometer Problem No Odometer Problem Record Found
Recycled No Recycled Record Found
Salvage Auction No Salvage Auction Record Found
Water Damage No Water Damage Record Found
Your Vehicle Checks Out! For this 1990 BMW 5-Series 525i (WBAHC2318LGB22627) no indication of an odometer rollback or tampering was found. We determine odometer rollbacks by searching for records that indicate odometer reading that are less than a previously reported value. Other odometer events can report events of tampering, or possible odometer breakage.
Information Found! AutoCheck found additional information on this vehicle. These records will provide you with more past history for this 1990 BMW 5-Series 525i (WBAHC2318LGB22627).
Accident Data Accident Data Record(s) Found
Corrected Title No Corrected Title Record Found
Driver Education No Driver Education Record Found
Duplicate Title No Duplicate Title Record Found
Emission/Safety Inspection Emission/Safety Inspection Record(s) Found
Fire Damage Incident No Fire Damage Incident Record Found
Lease No Lease Record Found
Lien Lien Record(s) Found
Livery Use No Livery Use Record Found
Government Use No Government Use Record Found
Police Use No Police Use Record Found
Rental/Fleet No Rental/Fleet Record Found
Repossessed No Repossessed Record Found
Taxi Use No Taxi Use Record Found
Theft No Theft Record Found
Below are the historical events for this vehicle listed in chronological order. Any discrepancies will be in bold text.
VIN: WBAHC2318LGB22627 1990 BMW 5-Series 525i
Event Date Event Location Odometer Reading Data Source Event Detail
07/16/1991 POMPANO BEACH, FL 27,000 Motor Vehicle Dept. PASSED EMISSION INSPECTION
09/17/1993 FL State Agency FRONT IMPACT WITH A BICYCLE (Case #:315307140)
06/08/1994 FL 95,000 Motor Vehicle Dept. PASSED EMISSION INSPECTION
05/17/1995 NY Independent Source INDEPENDENT INSPECTION
07/20/1995 NY 98,039 Motor Vehicle Dept. TITLE (Lien Reported)
10/23/1997 BRONXVILLE, NY Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
10/25/1997 BRONXVILLE, NY Motor Vehicle Dept. TITLE
10/07/1999 BRONXVILLE, NY Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
08/04/2001 NY 206,999 Motor Vehicle Dept. PASSED EMISSION INSPECTION
PASSED SAFETY INSPECTION
03/14/2002 BRONXVILLE, NY Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
About AutoCheck
AutoCheck Vehicle History Reports by Experian Automotive is the leading vehicle history reporting intelligence provider. With expert data handling, the Experian Automotive database houses over 3 billion records for nearly 500 million vehicles. Every AutoCheck vehicle history report will give you confidence when buying or selling your next used vehicle, with superior customer service every step of the way.
AutoCheck Vehicle History Report Disclaimer:
Experian's AutoCheck Vehicle History Report is compiled from multiple sources. It is not always possible for Experian to obtain complete discrepancy information on all vehicles; therefore, there may be other title brands, odometer readings or discrepancies that apply to a vehicle that are not reflected on that vehicles report. Experian searches data from additional sources where possible, but all discrepancies may not be reflected on the AutoCheck Vehicle History Report.
THESE REPORTS ARE BASED ON INFORMATION SUPPLIED TO EXPERIAN BY EXTERNAL SOURCES BELIEVED TO BE RELIABLE, BUT NO RESPONSIBILITY IS ASSUMED BY EXPERIAN OR ITS AGENTS FOR ERRORS, INACCURACIES OR OMISSIONS. * THE REPORTS ARE PROVIDED STRICTLY ON AN "AS IS WHERE IS" BASIS, AND EXPERIAN FURTHER EXPRESSLY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE REGARDING THIS REPORT. *
Experian shall not be liable for any delay or failure to provide an accurate report if and to the extent which such delay or failure is caused by events beyond the reasonable control of Experian, including, without limitation, acts of God or public enemies, labor disputes, equipment malfunctions, material or component shortages, supplier failures, embargoes, rationing, acts of local, state or national governments, or public agencies, utility or communication failures or delays, fire, earthquakes, flood, epidemics, riots and strikes.
* Except where buyback insurance is issued and, in such case, this disclaimer is modified only to the extent inconsistent with the express terms of the buyback insurance.
AutoCheck vehicle history reports are intended for personal use only. Any commercial use, resale and redistribution of AutoCheck vehicle history reports is strictly prohibited and may lead to deactivation of your account and imposition of additional charges for AutoCheck vehicle history reports.
These terms and the relationship between you and Experian shall be governed by the laws of the State of Illinois (USA) without regard to its conflict of law provisions. You and Experian agree to submit to the personal and exclusive jurisdiction of the courts located within the county of Cook, Illinois.
Buyback Insurance Policy Terms and Conditions for VIN: WBAHC2318LGB22627
Buyback Insurance
Subject to the following, First American Title Insurance Company (the "Company") agrees to pay the Insured the Insured's purchase price of the Vehicle if:
A. the AutoCheck Report was provided prior to the purchase of the Vehicle and on or after June 16, 2004; and
B. the Report reflects no Branded Titles as part of the Vehicle title history, but a Branded Title actually exists.
DEFINITIONS
1a. Branded Title- is a vehicle ownership or registration document issued by any of the 50 states of the U.S. (or the District of Columbia), issued with words or symbols signifying that the vehicle was: junked or salvaged; dismantled, rebuilt or reconstructed; flood damaged; fire damaged; hail damaged; bought back by its manufacturer ("Lemon Law" vehicle); odometer exceeds mechanical limits; odometer was not actual mileage; or which was issued with any other symbol or word signifying a similar brand.
1b. Excluded Brands- Specifically excluded from the definition of Branded Title are: ownership and registration documents originally issued without a brand but later stamped with a brand without being reissued; salvage titles issued due to theft; damage disclosure documents; and Branded Titles issued in error and later corrected.
2. Consumer- the person (other than a Dealer or Transferee) who ordered and paid for the Report prior to their purchase of the Vehicle.
3. Insured- the licensed automobile dealer ("Dealer") who ordered and paid for the Report and purchased the Vehicle or their Transferee who registers in accordance with item 12 of the Terms and Conditions. The term Insured also includes a Consumer who registers in accordance with item 12 of the Terms and Conditions.
4. Report/AutoCheck Report- AutoCheck Vehicle History Report.
5. Transferee- the purchaser of the Vehicle from the Dealer.
6. Vehicle- the passenger vehicle or light truck to which the Report relates.
TERMS AND CONDITIONS
1. The Insured must own the Vehicle at the time the claim is made. If the Vehicle is subject to a lien in an unpaid amount greater than the amount identified in item 8, this Insurance only applies if the Insured pays the Company the difference.
2. The Insured must complete and submit to the Company an executed claim form and provide a complete copy of the Report. The Insured must have run the Report prior to the purchase of the Vehicle.
3. The Insured must provide proof of ownership of the Vehicle in the form of the original bill of sale and a current vehicle ownership document issued to the Insured by the motor vehicle agency of one of the 50 states of the United States or the District of Columbia.
4. The Insured must provide a copy of the front and back of the Branded Title, certified by the issuing state authority. The Branded Title must have been issued at least sixty (60) days prior to the date the Report was run.
5. The Insured must deliver to the Company all ownership and registration documentation including, the certificate of title and certificate of registration, properly assigned by the Insured to the Company so the Company becomes the owner of the Vehicle.
6. If, prior to purchasing the Vehicle, the Insured knew, or had evidence, of the existence of a Branded Title for the Vehicle, the Insurance does not apply.
7. The Company will pay a maximum of the purchase price of the Vehicle paid by the Insured (plus warranties and other additional purchases such as installed aftermarket accessories, not exceeding a total of $500).
8. If the purchase price of the Vehicle in item 7 exceeds the NADA Used Car Guides used vehicle retail value at the time of the sale, the Company will pay no more than ten percent (10%) over the NADA Used Car Guides used vehicle retail value at the time the Insured purchased the Vehicle.
9. The Buyback Insurance will apply only if the Vehicle was manufactured in model year 1981 or later.
10. The Buyback Insurance will expire the earlier of (a) the date the Insured sells the Vehicle or (b) one (1) year after the date of the first Report run by or for the Insured relating to the Vehicle.
11. This Buyback Insurance is deemed assigned to the Transferee upon the sale of the Vehicle, provided that a copy of the Report is given to the Transferee and the Transferee registers in accordance with item 12.
12. In order for this Buyback Insurance to be in effect for Transferees or Consumers, they must register with the Company within ninety (90) days of the date they purchased the Vehicle. Registration may be made online at www.buybackinsurance.com or by writing for a registration form. The registration form must be completed and submitted to First American Title Insurance Company, Vehicle Title Insurance Division, TitleGuard Buyback Insurance, 12395 First American Way, Poway, CA 92064, USA.
13. Claims can be submitted to First American Title Insurance Company, Vehicle Title Insurance Division, TitleGuard Buyback Insurance, 12395 First American Way, Poway, CA 92064, USA. Please include name, address, telephone number, email address, the Vehicle Identification Number (VIN) of the Vehicle. Claim forms can be obtained online at www.buybackinsurance.com or by writing to the Company at the address above.
14. The Buyback Insurance will be governed by the laws of, and Insured consents to the exclusive jurisdiction of the courts of, the State of Illinois, United States of America.
(c) 2004 First American Title Insurance Company.
All Rights Reserved
