fuzzy thing around the door
  • raafhimself
    • Dec 2008
    • 451
    part number 51711906959 is fuzzy trim around the door, right?
    http://www.realoem.com/bmw/showparts...07&hg=51&fg=55
  • Red88
    • Nov 2008
    • 1161
    Yes. If you want it used, I can give you 3/4ths of them (missing the drivers door piece) for $70 shipped.
    Have you made a purchase from www.blunttech.com recently?
    sigpic<< wrecked
    • xLibelle
      • Aug 2004
      • 2673
      if you are making purchase to fix a seal leak in a corner, do not buy a new seal. It has shrunk slightly and is easily fixed. Top corner at the B-pillar is typical. Just pull the seal off at least a foot in both directions and tug it while replacing the bead towards the corner. This stretches the seal out to make for a tight fit into the corner.
      If for any other reason, replace.
      • raafhimself
        • Dec 2008
        • 451
        thanks for the tip tho- the fuzz on mine is drooping
        • txtorquemade
          • 1758
          Droopy fuzz???
          Sounds like a cop ... parked behind the road sign,,,,taking a nap....:weak:
          sigpic 1987 325is
