New To Forum, My First E30
  • dr.gonzo
    • Nov 2009
    • 206
    Hey everyone I am new here, traded my NA miata for a 90 325I yesterday. Blue over beige in pretty good condition. I have a few problems though
    Coolant leak, anywhere specifically these cars are prone to leaking?
    Oil leak, I know the oil pan gasket is pretty common.
    Sloppy shifter, I am guessing I need to rebuild some of the parts
    It's saying my tail lights are out when they are not.
    If someone could point me in the right direction that would be awesome and I will have pics up tomorrow.
    www.roadreview.net
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    LED's?
    • dr.gonzo
      • Nov 2009
      • 206
      Yes the LED's
      www.roadreview.net
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        I was asking if you have LED taillights, or some silly ricer mod. Lights will work, but the check panel will inform you something is wrong.
        • dr.gonzo
          • Nov 2009
          • 206
          No, The car is completely stock, please don't think that because my last car was a Miata I am a madtytejdmcooliodorrifto enthusiast. I have been working on cars since I could walk and my previous car was a 02 golf gti 1.8t big turbo, I have been part of vw vortex and the car lounge (currently on the same sn over there and before that i had a different sn)
          www.roadreview.net
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            Clean all the bulb bases/housings with a wire brush, then lubricate with dielectric grease.
            Rent a pressure tester from AutoZone to find your coolant leak...
            • bimmerboy08
              • Apr 2009
              • 353
              for the coolant leak first off feel on your bypass hose where it goes by the radiator cooling fan. Sometimes the fan will hit the hose and cause a tiny hole over time.
              • dr.gonzo
                • Nov 2009
                • 206
                Thanks I will look for those leaks tomorrow and work on those bulbs tonight! I will also post some pictures up in the daylight, I am guessing the oil leak is from the oil pan since the records that came with the car indicate that.
                www.roadreview.net
                • graphikg
                  • Jan 2008
                  • 1614
                  for the oil leak, check the oil sensor plug in the oil pan. That may be a place.
                  • dr.gonzo
                    • Nov 2009
                    • 206
                    What other types of maintenance should I do.
                    www.roadreview.net
                    • dashboardmonkey
                      FUCK YOUR WAFFLES
                      • Jun 2008
                      • 6158
                      timing belt, water pump, oil change, brake fluid flush, transmission/ differential flush, oil change, air filter, motor mounts, trans mounts, cam seal. that's most of the shit I do when I pick up an E30.
                      -Andy
                      • e30trooper
                        • 11576
                        Dr gonzo . Come to the meet this friday . Its Van Nuys at " The Plant " Next to In n out on Van Nuys blvd. We eill help you. I go out to North Hills weekly. You need to meet the Locals! Dont miss it!!!
                        • dr.gonzo
                          • Nov 2009
                          • 206
                          i just replied trooper, the timing belt water pump was done recently (receipt verified) i think tomorrow will be fabbing up the brackets for my sparco and finding the coolant leak
                          www.roadreview.net
                          • TimKninja
                            • 2131
                            You change the Oil twice when you get an E30?
                            1985 325e M50TU(Sold)
                            1991 318is Slicktop (Sold)
                            1990 325is Brilliantrot S50/5 Lug Swapped.
                            1992 525i Manual shitbox Winter Beater
                            • dr.gonzo
                              • Nov 2009
                              • 206
                              He just loves it THAT much. I will be ordering the oil pan gasket today and when that comes it I will be changing the oil/ seafoaming the engine
                              www.roadreview.net
