Turbo Eye Candy
  • TCD
    • 438
    Turbo Eye Candy
    The T04B that's going on the 325i.
    [img]http://groups.msn.com/_Secure/0QwDTAq8R4yWqBPY*Ryy0xTihwjFDK4xXxEZRKEpIivoZsGd80 jN9ziVET5bAhfjChYILMc0e5ui!Er6kSgtmICKFNrsbN2nCQVL iFxm3NGg/IMAG0011.JPG?dc=4675449642005310351[/img]
    Todd
    turbochargingdynamics.com is available for sale! Check it out on ExpiredDomains.com. turbochargingdynamics.com is in high demand, secure it today!
    TCD
    1985 euro 535i
    503rwhp/485rwtq
  • Rob
    • 8166
    sexy, but all we get is a picture? :P
    BEERTECH
    • matt325is
      • 409
      Thats a VERY nice looking turbo you got there. Do you know what the A/R values are on the turbine and compressor? Looks sick, I bet it should put out some nice numbers. This might be some competition for me :D What kind of boost are you going to be running? Any internal mods?
      Peace out,
      matt
      • TCD
        • 438
        Hey Matt,
        We had the turbo built to our spec. Email me directly if you would like to know the specs. I believe they are similar to yours. I intend to run 10psi non intercooled and 15psi intercooled (water/air). No internal mods planned. If the m20 is as stout as the m30 then none are needed. My parter has run 18-20psi on his stock m30 for 30k miles with no issues. I am going to check to be sure it has the updated head bolts. Was there a production date where the m20 went to the tork head bolt?
        Thanks,
        Todd
        TCD
        1985 euro 535i
        503rwhp/485rwtq
        • Brian 89 325i
          • 1450
          If anything just get the head studs, they are stronger and work better.
          Brian
          • LarsG
            • 59
            You can just look through your oil filler opening to see if you have the hex head bolts. They were on E30s from '84 to '89, and it is definitely worth getting them replaced with the torx head.
            • TCD
              • 438
              Sweet. Just checked and have torx head bolts.
              Todd
              TCD
              1985 euro 535i
              503rwhp/485rwtq
              • 325 eta
                • 472
                what are the power gains on that turbo for an e30 a 325e 85
                • TCD
                  • 438
                  Well, that turbo is a little to large for the eta. I'll probably go with a straight T3 for the eta. Figure about 8/9rwhp per pound of boost non intercooled and 10/11rwhp intercooled. I am shooting for 10psi non intercooled and 15psi intercooled.
                  Thanks,
                  Todd
                  TCD
                  1985 euro 535i
                  503rwhp/485rwtq
                  • spud814
                    • 287
                    wow, i learn something new everyday, i didn't know we could run turbos on our cars w/o internal mods and w/o intercoolers. And your saying that a regular m20 could get 10psi w/o a intercooler, so its' like almost 80hp. So what is necessary for a turbo setup? I know u need the turbo, the waste manifold(that metal things that bolts to where the headers are suppose to be) and thats it right? And is it a waste to run turbo on autos?
                    • TCD
                      • 438
                      I currently run 15psi non intercooled on my m30. It has 8:1 compression. Mathmatically I should be able to run 12psi on a 8.8:1 motor but I say 10psi to be conservative. We have made no internal mods to the m30 and hope that the m20 motor is as robust. We have no reason to suspect otherwise.
                      A properly sized turbo and an automatic are a great combination.
                      Thanks,
                      Todd
                      TCD
                      1985 euro 535i
                      503rwhp/485rwtq
                      • Grabgears
                        • 5
                        I'm in for one when you get the R&D done on the kit. Seems a bit pricey to me for the intercooled kit though. IS the boost adjustable from the cockpit and does it come with a boost ignition retard??
                        You could easily run 20psi of boost on a stock M20 engine. Conquests/Starions are known to run 30 psi boost on stock 8.5:1 pistons, and they have a shitty induction (read: fuel management system) on them.
                        • TCD
                          • 438
                          The MSD is an option and boost is not cockpit adj. I have priced the kit fairly and it is a very good value compared to the competiion.
                          Thanks for your interest,
                          Todd
                          TCD
                          1985 euro 535i
                          503rwhp/485rwtq
                          • kidrobot
                            Nekomata
                            • 712
                            TCD do you think that your shop will end up doing kits for the M50 or S52?
                            That would be something I'd be VERY interested in taking a look at.
                            「 Terror from the Rising Sun 」
                            • skat 325is
                              • 296
                              Looks niceee, heres mine
