going to look at a 91' 260K 318is as a possible buy, $2K obo. this will be my first e30. normally, I wouldn't even think about buying a car with soooo many miles, but being on here for awhile and reading how tough these cars are has made this a hard choice.the current owner says the car runs fine, so its gonna come down to searching for anything that could possibly go wrong. I plan on driving the crap out of it on the test drive, check for clutch slippage, see if the lsd still grabs, and just do a quick look at the vacuum lines. if the car does indeed run/idle well and everything seems to work, what else should I look for besides the oil pan leak and timing chain rattle? any other areas to look for? Not too worried about bushings(i plan on replacing them anyway). should I split the bill with the owner for a compression test?
when buying a 260K 318is?
[All the Bronzit haters]
