How is this Possible..?
    fixed
    Poor ground? WTF is "kick starting" a car?
    '89 325i track sloot
    '01 530i daily
    -Enginerd
      kick-start also known as push-start.
      here is how you do it:
      Discover hacks, tips and tricks to help you solve any problem in your home, repurpose used items and more.
      lol..
        Ah, I've push-started several. I reserve kick-starting for dirtbikes and old street bikes.
        '01 530i daily
        -Enginerd
          How are you checking for spark? Are you just looking with one cable? Or at the coil? Maybe only one or two cylinders are not getting a spark.
          Originally posted by Kershaw
            Sounds Like you could have a bad Cap and Rotor, push start would at least get some current moving. that's my guess
            stephenbrody.com
              Battery? When you push start the car, the alternator is spinning, charging up the battery and help run the coil to get enough power to spark. When it is sitting still, the battery might not be strong enough to charge the coil to create a spark.
              RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
              Welcome e30 (brilliantrot '90 325is) 12/23/06
              DaveCN = Old Man
              My signature picture was taken by ME! Not by anyone else!
              If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                Ya, but he can crank the engine with the key.
                  I removed the cables (one by one) and checked for spark.
                  That was my guess. A weak battery might be causing this but it cranks hard when I turn the key and the battery is 6-7 months old.
                    Doesnt mean the battery isnt weak though.
                    DaveCN = Old Man
                      Poping the clutch is what its called. Check grounds and check your battery wires. It wouldnt be there rotor becuase if it was you would have no spark/start/clutch popoing starts..etc etc . Its a wire issue
                        hmm alright I will check the wires. Maybe the ECU is acting up or main relay..
                          In for the dirtbike style kickstart DIY ;)
                          Originally posted by Beej '86 325es
                          every time an M-tech 1 spoiler is destroyed, a baby seal dies.
                          Originally posted by Jparkr
                          The last thing we need are more of the retards on here thinking they are engineers too.
                          87 325:83 jetta coupe:99 volvo c70:99 volvo s70
                            i call it bump starting lol
                              Step 1: Put a breaker bar on the end of the crank snout
                              Step 2: Make sure the car is in the "on" postion and in neutral
                              Step 3: Jump like a MF on the breaker bar.
                              Step 4: Hope the breaker bar and socket fly off without maiming you or the car.
                              '01 530i daily
                              -Enginerd
