I NEED AND DRIVE AXLE REMOVING TOOL IN NY/CT Area!
  • freeski27
    • Sep 2009
    • 388
    Hey guys, I need one of those axle removing tools, figured I would come on here and see if anyone could lend me one before I go out and buy one. It would be much appreciated!!
    Thanks
    E30 325is "Starting from Scratch" build thread
  • SamE30e
    • Sep 2007
    • 4319
    You mean a mallet?
    Just wack it out.
    1985 325e 2.8 Turbo VEMS
    • gtarwiz
      • Jan 2009
      • 591
      you can also rent them from autozone or advance if you want to be a little more gentle with them.
      BMWCCA # 482566
      Originally posted by nando
      also, I can't think of any BMW special tools you need to do a headgasket on an M20. you could nearly do it with the trunk tool kit, some bubble gum, and string.
      Check out my Leather Shift Boots for Sale Here
      Check out my other work with my GF Here Great gifts for your Wife or GF
      • Naplm00
        • Nov 2008
        • 1573
        i use a air impact hammer with a pointed anvil.
        88 325ic ~~~> Rusty and ugly
        85 E ~~~> RIP
        • TexasTerp
          • Jan 2009
          • 3541
          this
          a mallet works just as well.
          stephenbrody.com
          • FredK
            • 14763
            Sometimes the halfshafts get really stuck.
            In this case, heat the hub a bit with a torch, then try to pound the axle out, or rent a puller (free) from Autozone / Advance Auto Parts.
            • freeski27
              • Sep 2009
              • 388
              well, I have an air hammer; but I can't even get the axle nut off. I'm sorry if this sounds really noob, but I've tried it all and just cant get it... So I looked in my Bentley manual and it Looks like you have to turn the axle out of the nut; where as I was trying to turn the nut off of the axle. I could try heat, but am I just doing this wrong?
              • SamE30e
                • Sep 2007
                • 4319
                Breaker bar, and a pipe! It's just really stuck.
                • bataangpinoy
                  • Jul 2008
                  • 1636
                  i have the socket for the nut if you wanna borrow it.
                  My feedback:
                  http://www.r3vlimited.com/board/showthread.php?t=186328
                  http://e30tech.com/forum/showthread.php?t=74911
                  Instagram:
                  @gears_n_glory
                  @functionmotorsports
                  • gtarwiz
                    • Jan 2009
                    • 591
                    This may seem like a stupid question but did you take the secure plate that is around the axle nut? Because that will prevent you from getting that nut off. If you haven't taken it out, you will have to chisel that thing out.
                    BMWCCA # 482566
                    • BrewCity11
                      • Mar 2008
                      • 2335
                      this
                      and/or this
                      turk@gutenparts.com
                        • 37833
                        Take off the nut locking plate. Hit the axle nut with some penetrating lube, hit the axle nut with a nice 1/2 inch drive air gun.
                        Grover Beach, California
                        BimmerHeads.com
