...how bad head gasket failure has damaged an engine? I'm thinking about Possibly buying a car that has a blown head gasket. I know the effects could range from just a blown gasket, cracked head, and recently learned a cracked block. Is there a way to tell how bad the damage is?
Is there a way to tell...
All i can say is expect the worse and hope for the best.
Thats what i do now
89 325i S50/ZF E36 M3/TI 5lug Style 32s
My feedback Thread http://www.r3vlimited.com/board/showthread.php?t=219113
Originally posted by jp_slick View PostAll i can say is expect the worse and hope for the best.
Thats what i do now
It's a helluva bargaining chip when you're buying a car that needs known work because of a head gasket. At a minimum the mating surfaces need to be decked and the gasket has to be replaced; you have no idea how long the engine was run once it failed. A complete teardown will cost you even more making the shell of the non-running car less valuable (to you as the buyer!)- Sco
Keep Our City CLEAN & SAFE Do Your Part
