removing the door stop
  • duboy
    • 83
    my drivers side door stop is broken so it swings freely. I tried to take an arm off of an e30 at a pick n pull and i couldn't get the arm off the door frame. I took off the door panel and then unbolted the 2 10mm bolts that hold it to the door, and i took off the bottom clip on the section of the arm that attaches to the door frame, but after that i couldn't take the pin (or whatever it is that holds the arm to the frame) out. do you just push the pin up with some force to disconnect it, and then thread the door stop through the door itself? anyone done this?
    | '89 M3 | '93 M5 | '03 X5 4.6is | '03 325i | '87 190e 2.3-16 |
  • whiltebeitel
    • Apr 2007
    • 2098
    Yep, you have to get something like a screwdriver to get on the uderside of the pin, and tap it with a hammer. It'll come out with a little persuasion.
    '89 325i track sloot
    '01 530i daily
    -Enginerd
    • duboy
      • 83
      son of a....i figured that would be how, but the one at the yard just wouldn't come out so immediately i figured i was doing it wrong. well, thanks for confirming it, i'll hit harder next time.
