The brackets bolt up to any rear seat. Bolt them in, make a couple small cuts in the top and pop in the grommets. Add a set of headrests and you are good to go. If you pull out your back seat you should see where the brackets mount to.
you can buy the headrest brackets and parts from www.getbmwparts.com for about $30 and then you need to pick up a set of head rests from either the yard or someone on here.
I think they look great in 4drs, not so much in 2drs. The brackets aren't NLA - Tischer BMW has them for $18.62, if I remember correctly they come as a pair, it's like $25.00 for all of the parts.
