A little Update.
  • 325ixE30
    • Oct 2009
    • 429
    A little Update.
    I just installed a M30 AFM and 19lbs injectors.
    I have a Turner chip.
    I noticed a little difference in throttle response and a bit more power but not to much.
    Satisfied with it.
    I just need to figure out how im going to add a air filter.
  • 325ixE30
    • Oct 2009
    • 429
    Originally posted by Matt-B
    on red car?
    Correct.
    And if you are thinking im wasting money on the red car its just parts of the M30
    • 325ixE30
      • Oct 2009
      • 429
      how did you get injectors in and out? When i swapped 19lbs into mine it was a bit difficult cause the O-rings were old and dried out
      O rings at discount are a few dollars.
      • Jand3rson
        • 37587
        Remove cover from airbox.
        Remove air filter.
        Installation is the reverse of removal.
        • kid325e
          • Sep 2007
          • 6421
          Sweet!
          clutchCTRL!
          Move with a purpose.
          - 1991 325iX 4dr/5spd
          - 2000 323i AT
          2016 Mazda CX3 Sport AWD
          • Red88
            • Nov 2008
            • 1161
            I was under the impression you're not supposed to re-use the o-rings. Is this correct?
            Have you made a purchase from www.blunttech.com recently?
            sigpic<< wrecked
            • Jand3rson
              • 37587
              You shouldn't. I've always been of the opinion that you shouldn't reuse things like gaskets and o-rings, they're cheap and replaceable for a reason.
              • 325ixE30
                • Oct 2009
                • 429
                I replaced the orings
