Retrofiting late model fuel pump
  • Fendego
    • Nov 2008
    • 124
    I'm looking for a quick answer or else this would be in Gen Tech. Anyways I have an 87 car with dual fuel pumps and I have a late model pump, bracket, and pickup. What needs to be done to convert to a single pump setup? Do I need anything else? Thanks guys :)
  • Brian 89 325i
    • 1450
    Its a pretty involved job. You have to reroute the return lines and to do so you need to drop the tank.
    • Fendego
      • Nov 2008
      • 124
      Ah ok, thanks. Is the high pressure pump on the early model the same as the out of tank pump on the late models? Meaning can i use the pump I bought in place of the out of tank high pressure pump?
