What would be a good swap to consider?
  • e30s52
    • Oct 2007
    • 5235
    #31
    Originally posted by Simon S
    supercharge the m42
    318isc
    332isc?
    www.gutenparts.com
    • freeski27
      • Sep 2009
      • 388
      #32
      go to VACMotorsports.com
      and type this in the search box:
      VAC-FR-S14
      seems like a good option for you in my opinion. expensive... but worth it if you have the money to spend.
      E30 325is "Starting from Scratch" build thread
      • z31maniac
        • 17566
        #33
        Originally posted by dinanm3atl
        And S52 is an M52 bored and stroked with some cams in all reality. If I remember the cylinder walls on an m52 are ~6mm and on the S52 they are 3 or 4mm thick.
        If you want to boost the M52 is a better motor.
        Think about it though. You spend an extra 2K on an S52 and 1500-2000 buys an S/C. So you have a motor and a blower for the price of just a motor.
        Aren't there plenty of blown S52s still pushing well past the 600HP mark though? Didn't think it was that much of an issue.
        www.gutenparts.com
        • daniel
          • 6703
          #34
          Originally posted by herbivor
          So, since I'm considering the same conversion, how much was your conversion? I imagine you had to stiffen up the chassis with some bracing or a roll cage and buy coilovers to handle the extra power properly. I can see doing the driveline and exhaust for $5k but the suspension, reinforcement, brakes, rims and tires may bring it over a bit. Do you run 225 on the rears and 215s up front to handle the power? An E36 M3 non-staggered runs 235's I believe. With the same amount of power and a lighter car I'd think 225s would be the minimum at the rear. Hell 245's maybe.
          dude, 240hp is not that much in an e30. you don't need to cage the car just because you are adding a bit of power. before i had this car i thought the same thing- "there's no way i could drive a swap car every day. certain stuff won't work, way too much power, etc". it just isn't true. S52s are very smooth- it's not like every time you pull away from a stop you are doing a burnout. it is easy to forget the motor is even there until you put your foot down.
          anyway, you don't have to have a full race suspension, either, to have an S52. as for tires, i currently have 225's on all 4 corners but there are plenty of people who run 205's for stretch purposes and they aren't sliding straight off the roads due to lack of traction. i'd recommend 225's, but that's just me. it also depends on what wheels you are running. i'd upgrade to a 15 or 16" wheel just so you could get 225's and also get a better tire selection.
          you seem really worried about understeer. running a staggered setup like 215's in the front 225's rear, or 225's front 245's rear is just going to create a difference in traction capabilities of the front and rear and you guessed it, create more understeer (relative to a non-staggered setup). but again, it's not like you have a boat anchor sitting on the front of your car and every time you corner you are having to slow down all the way. in fact, my car pretty much never understeers unless i induce it. in auto-x i suppose it would understeer a bit, but much of that could be controlled by driving smoothly.
          another thing. e30 brakes are already really good. you don't have to go 5-lug or to a BBK. it is overkill unless you have a set of 5-lug wheels you just absolutely insist on having. even though upgraded brakes will help if you are autocrossing, a good set of pads is all you need.
          as for the cost- i paid $6500 for the whole car with the swap and 5-lug.
          http://instagram.com/dslovn.drives
          • herbivor
            • Apr 2009
            • 1420
            #35
            ^Good info thanx and a helluva price. Did you run a different brake booster?
            • dinanm3atl
              • Feb 2007
              • 7305
              #36
              It isn't a HUGE deal but many of the big daddies are running M52.
              • e30s52
                • Oct 2007
                • 5235
                #37
                You have to or you can notch the intake manifold.
                www.gutenparts.com
                • Simon S
                  • Oct 2004
                  • 3758
                  #38
                  318isc
                  Originally posted by e30s52
                  332isc?
                  even better
                  -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                  • freeski27
                    • Sep 2009
                    • 388
                    #39
                    no one else seems to think a VAC MS Racing S14 would be sweet?
                    • PeaveyBassist
                      • Sep 2004
                      • 3511
                      #40
                      Get a turbo F20. Still a 4cyl that makes a lot of power.
                      RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                      Welcome e30 (brilliantrot '90 325is) 12/23/06
                      DaveCN = Old Man
                      My signature picture was taken by ME! Not by anyone else!
                      If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                      • stegosaurus
                        • 367
                        #41
                        s38b38
                        • FredK
                          • 14763
                          #42
                          That would be a sick engine. If the car were built around the engine, it would be insane on-track. A BUILT S14 is truly nuts. It also costs an arm and a leg.
                          • Simon S
                            • Oct 2004
                            • 3758
                            #43
                            dude..
                            with a 10K budget..
                            SUPERCHARGE THE M42 !!
                            flat torque curve
                            minimal weight disturbance
                            no motor-pulling/transporting/installation hassles
                            simple
                            bolt-on fun
                            car retains original hardware / ‘ease-of -returnability’ to stock.
                            from research i've done, performing level one suspension upgrades + supercharging = an economic [factory] M3 equivalent. (~195HP e30 with 4 cylinder motor - s14 headaches)
                            • Stu
                              • 4083
                              #44
                              Always liked the idea of an F20 swap, it makes a lot of power and weighs a LOT less than an M42. Would be dynomite in a non-sunroof 318is IMO.
                              • Alpina
                                • Oct 2004
                                • 838
                                #45
                                Originally posted by stegosaurus
                                s38b38
                                Cool,,,,, but not wise
                                Sveinbjörn Hrafnsson
                                E30 CABRIO V12 M70B50 ///
                                ALPINA B10 BITURBO 346 @ 507
                                E34 550 V12 JML
                                Finnish wisdom : If you want to Win,, hire a Finn
                                http://alpina.123.is/pictures/
