Get it running again...
After changing the battery and the fuel lines, I would def change the oil and I would try to lube the cylinder walls with some lube to free uo any rust BEFORE you ever try to crank it.Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.
