M42 Tensioner Failure -- How bad?
  • recall
    • Apr 2009
    • 120
    Found a 318is up for sale and I'm thinking about picking it up for a DD. The timing tensioner has failed and the owner apparently doesn't want to fix it, saying the timing is off and a special tool is needed to put everything back in time.
    So my question is how bad could a failure of the tensioner be? And how tough of a job is it to fix it up? I'm somewhat familiar with the M20 and recently replaced a timing belt, but the M42 is an entirely different beast. Owner says that he lined the chain up (though a tooth off on the intake side?) and ran a compression test that indicated close compression across all 4, citing this to say that there's been no damage to the valves/head when the tensioner failed and the fact that the engine wasn't under a heavy load when it went kaput.
    Since I'm new to things, I'm wondering what else I should check for as an indicator for potential problems coming from this failure?
  • FredK
    • 14763
    Just replace the entire engine.
    The hydraulic tensioner does not fail. The chain rails let go because they are made of plastic from recycled Legos and milk bottles, and when they do, pistons hit valves, unless the owner killed the engine in one engine revolution. Right.
    Did you ask what the "close compression" was across cylinders? Maybe 50 psi?
    • kencopperwheat
      King of Kegstands
      • 14396
      The tensioner itself is like 50 bucks and takes ten minutes to change.
      I'd put a new tensioner in, time it correctly, and do a compression test yourself. Look for 190+ in all four cylinders.
      Originally posted by Gruelius
      • xwill112x
        • Jan 2009
        • 4236
        not exactly. i've personally seen a m42 with a "failed" tensioner. lots of rattle and knocking and clacking due to the chain just slapping around.
        • FredK
          • 14763
          Yes. Then you put a new tensioner in, and in the interim, because you've run with low chain tension for such a long time, the cam gears are worn as hell, and the plastic guides are grooved.
          M42 does well with preventative maintenance, not reactive maintenance.
          Look at the cam gears. Touch the teeth. If they are sharp, plan on replacing a lot of parts.
          • tjts1
            • May 2007
            • 1851
            Who cares about the cam gears. Slap in a new tensioner and drive the snot out of it until it fails completely. Replace the engine whenever that happens.
            • recall
              • Apr 2009
              • 120
              He said the compression was 180-185 across, which might be low. Maybe within the bounds of measurement error?
              He did specifically say the cam gear teeth weren't sharp, so maybe that's a good sign. I'll definitely check that out for myself. How bad is timing the M42?
              I'm curious if he's dumping the car for reasons beyond this, obviously harder to find when the car isn't drivable, but first I need to make sure this problem can be fixed without too many headaches.
              • xwill112x
                • Jan 2009
                • 4236
                if it runs, buy it.
                • 325ix
                  • Aug 2009
                  • 7783
                  whats he asking for it?
                  • recall
                    • Apr 2009
                    • 120
                    A grand. He says the intake sprocket jumped a tooth when the tensioner failed, though I'm guessing a tooth on the M42 could be worse than a tooth on the M20 camshaft.
                    • tjts1
                      • May 2007
                      • 1851
                      Too much. Offer $500 depending on the condition of the rest of the car.
                      • 10Toes
                        Me Father Was A Tree
                        • Jan 2008
                        • 61222
                        Thats not too much if it is clean. If it is only off one tooth then the engine is probably fine. I would get it take the timing cover offf and see what it looks like and then go from there.
