I may have put my cooling system back together not 100% correct lol so I need some help. #1 there are 2 hoses that connect to the heater core on the firewall. Should the hose coming from the block connect directly to the top or the bottom? #2 there is a weird hose contraption, possible called the spider hose?? that is in between there. What is it for and were does it go?
Also IIRC on most cars the inlet of the heater core comes directly from the block and the outlet goes to the thermostat? Is that correct? And if so which is the inlet and which is the outlet, top or bottom? Thanks a lot for the help in my time of frustration :D
