E30 work
  • bpmack16
    • 1521
    E30 work
    How hard is it to replace the rear main seal on an e30?
  • JMPAuto
    • Jul 2009
    • 356
    Same thing as replacing the clutch. Most likely a whole day job doing at your garage.
    JMP Autowerkz
    7349 Canby Ave.
    Reseda, CA 91335
    818.457.4967
    www.jmpauto.com
    • dashboardmonkey
      FUCK YOUR WAFFLES
      • Jun 2008
      • 6158
      even with a lift it could take all day
      -Andy
      • Trucidatio
        • Apr 2009
        • 784
        I just replaced one earlier today.
        Its a simple job itself, But actually getting to the seal is god damn ordeal.
        "I go slow, cause;Slow is smooth, and smooth is fast."
        • z31maniac
          • 17566
          Yup, and you might as well put a fresh clutch kit in and resurface the flywheel while you have it apart.
          Also a great time to redo your shifter bushings/and E36 lever, while you've got it apart.
          www.gutenparts.com
          • bpmack16
            • 1521
            10- thanks. It there a posting on it that anyone can find.
            • FredK
              • 14764
              There are a few pictures and instructions in Pelican Parts's clutch replacement writeup:
              http://www.pelicanparts.com/bmw/tech...ch_Replace.htm
              You must remove the engine flywheel to get to the RMS carrier. The carrier will slip off the crank once the bolts securing it are removed. It will take light prying to remove the carrier.
              When you install the new RMS, be sure to install it at a slightly different depth than the old one, otherwise, it'll leak again. A hair deeper is fine.
              • Sean
                • 5793
                This man speaks the truth. Worth replacing the flex disc if it's at all worn too. Replace tranny mounts if worn.
                - Sean Hayes
                • M-technik-3
                  • 18946
                  The bad thing is they don't always stem the flow of oil on 24V engines. I replaced mine twice and quit after that, it was far easier to put a pig blanket under the car to absorb the leak.
