325e 21mpg?? should it better?
  • richardkeith97
    • 1693
    i'm gettin 21mpg in my eta. should it be more? its an automatic. thanks
  • Raxe
    • 5346
    Depends on way the way you drive it.
    • richardkeith97
      • 1693
      mostly highway. i don't beat on it
      • M-technik-3
        • 18946
        Air Pressure? Ever 10 degrees of temp below freezing psi falls 1 degree. Last time you changed fluid and filter?
        Typical fuel filter? Plugs cap and rotor?
        I get 24 average with my auto vert with hardtop on it.
        Was getting in the 18's at the beginning of the month after the car sat for about 3 week with sub temps.
        • kronus
          • Apr 2008
          • 13027
          I get about 21 in my eta :|
          cars beep boop
          • Holland
            • Nov 2008
            • 7178
            21 can't be right. I can do better, not by much mind you, in my M10. Would that be related to the auto?
            Originally posted by DEV0 E30
            • M-technik-3
              • 18946
              Auto's use more fuel as they are not as efficient in the older style transmissions.
              • Holland
                • Nov 2008
                • 7178
                That's what I thought. I get roughly 23mpg flogging it with a 5spd and a 3.91.
                • Quadrajet
                  • Jul 2008
                  • 1278
                  also Holland it's probably warmer where you're at year round. My eta will average 22-25 until the outside temps pick up. What's more telling is my Highway mileage which now is 26mpg but will jump to 30 in the Spring and Summer. When we see 90's up here my cars do their best.
                  • e30e
                    • Dec 2004
                    • 2176
                    Used to always get 24 mpg beating the piss out of mine
                    1985 BMW 325e
                    1997 BMW M3/4/5
                    2007 Chevy Silverado Crew Cab 5.3 v8
                    • Raxe
                      • 5346
                      I can get around 25mpg driving the wheels off of it.
                      • kid325e
                        • Sep 2007
                        • 6421
                        same!
                        clutchCTRL!
                        Move with a purpose.
                        - 1991 325iX 4dr/5spd
                        - 2000 323i AT
                        2016 Mazda CX3 Sport AWD
                        • Aptyp
                          • 6584
                          highway with 5sp, i get low 30s on a long trip and upper 30s if I stay 70 entire way in 5th, auto should be even better with longer overdrive.
                          • e34john
                            • Apr 2006
                            • 3599
                            you should be doing better. I get that kind of MPGs in my i with some wide summer tires.
                            • tjts1
                              • May 2007
                              • 1851
                              Originally posted by kronus
                              Funniest shit I've see all day. Thanks for the LOLs.
