Used fuel tank?
  • IminDiegoTriick
    • Oct 2009
    • 1564
    Used fuel tank?
    Would you buy a new fuel tank or a used one? & in buying a used one, what would you look for to make sure it is 100%
    Fast life fuck slow..Low life for life
    Let the mix flow..Let the night flow
    I'm so gone ✗ ♥ O
  • ak-
    • 12422
    No rust?
    1991 325iS turbo
    • dannyg
      • Mar 2007
      • 1553
      Just make sure theres no rust, no dents, etc.
      1993 325ic Schwarz/Natur
      1991 318is Black/Black - Slicktop - Project s52
      1989 Alpine White/Black M3 S52
      1988 Henna/Pearl M3 <3
      • IminDiegoTriick
        • Oct 2009
        • 1564
        I will be buying one.. and installing it myself. is there any instructions or enlightment I can know for when I install it? I checked the Robert Bentley and theres nothing at all about it and I used the search engine. .
        I'm so gone ✗ ♥ O
        • Jean
          • 18228
          You'll need to remove driveshaft and exhaust out of the way. Pull the rear seat and fuel pump / fuel level sender covers, disconnect everything. It bolts to the bottom of the car, you need disconnect/unhook all the various lines going to and from it. Maybe even drain the gas from the passenger side from your old tank.
