diff whine?
  • 87-325ic
    • Apr 2006
    • 1198
    diff whine?
    My differential has been making alot of noise lately. it sounds like my rear seats are out but they arent.
    is it time to change my gear oil again? its redline synthetic in there, but it was like 3-4 years ago that i changed it and its recently started making that loud hum.
    will cold weather and older oil cause this or what?
    thanks
  • Mike325
    • Mar 2006
    • 3685
    The oil and cold could cause the noise yes. I would change the oil to something that has some type of LSD conditioning in it, if you have an LSD. I think that redline stuff has it in it though. Does the noise happen more or less when you turn to the right or left? Does it get better as your car warms up? Any vibrations?
    Originally posted by Kershaw
    • UDelaware30
      • Dec 2009
      • 336
      have you replaced the diff mount to poly? When it is cold, my diff makes some noise because of the 75d poly mount.
      • TheB1G Lebowski
        • 593
        make sure there is still fluid inside. Check the pinion seals and axle seals to see if they are leaking. If its making a whining noise already and increases with speed, its prob already done for. The bearings have more than likely already been damaged and need to be replaced. And as stated above if you have a LSD then you need some friction modifier to be added to the fluid as well.
        1989 325i - sold
        1987 RX-7 Turbo II - sold
        1990 325i
        • svn2002s
          • Sep 2004
          • 486
          +1 on some additive
          • ieatpeople
            • Mar 2008
            • 883
            yup, my 87is droned like it needed a wheel bearing, and make funny noises on turns. changed the fluid, put the lsd additive in, no more noise.
            Originally posted by BillBrasky
            That's like Vlad challenging Chip Foose to a car painting contest.
            Originally posted by acolella76
            i'm pretty sure 'Phillis' is short for syphilis
            2007 CVPI, stock and slow
            1994 tercel, 5efhe swap, i/h/e
            1984 t-type, 5.3/th350 swap in progress
            My newest addition:
            Rebecca Arlene, born 4/19/2013
            • 87-325ic
              • Apr 2006
              • 1198
              the redline gear oil doesnt have the LSD additive? i thought it did..
              its been a few years since i replaced it. it never really leaked before, im thinking its just the coldness. it seems to go away a little bit when warmer..
              its not a vibration or anything, just an audible, speed related whine.
              ill check the fluid level soon, but i may just replace the fluid.. its just such an annoying affair to go buy a pump. save the fluid, and then try to find someone to recycle/ take it.
              • Wh33lhop
                • 11705
                There are two types of Redline diff fluid, the "LS" type has friction modifier additives and the "NS" type does not. (The friction modifiers are not your problem though, and you'd probably know if you didn't have any as the diff would chatter around corners)
                It's possible that the seals were just old and the synthetic fluid seeped through them slowly. Check your fluid level.
                My diff has always whined, for what it's worth. I'm not really worried, from what I understand it's pretty normal for the LSD units.
                paint sucks
                • T Verdier
                  • Aug 2007
                  • 2636
                  I don't know if this helps but my diff was fine when I chose to change the fluid , I put some aquatorque in it and months later I had less lock on my diff. it would act like an open diff every now and then. A year later now I pretty much have an open diff 80% time and an LSD the other 20% of the time, very unpredictable and annoying. It could have been a coincidence but with my next LSD I wount be adding anything but diff fluid.
                  • Wh33lhop
                    • 11705
                    Is it an open at low speeds/sharp turns in first gear/donuts and an LSD otherwise (hard corners, second gear+)? Because there's an explanation for that.
                    paint sucks
                    • ck_taft325is
                      • Sep 2007
                      • 6880
                      I've had 5 LSD's and 2 of 5 whined a bit. I'll be putting Redline Diff. Fluid (LS additive) in my DD simply to prevent it from "worsening". Only one of the 5 really quieted down after flushing it out and replacing. 50/50 chance I imagine. I really do want to get a spare to rebuild just to say I have ;)
                      Need a part? PM me.
                      • T Verdier
                        • Aug 2007
                        • 2636
                        Kinda.
                        Example: I'll drop the clutch and both wheels break loose and the back of the car starts to drift out, then it all of the sudden and jerkeley caught it self and spun only one wheel.
                        The other day on a drive I made a sharp turn and the inside wheel spun and the car barely went anywhere.
                        I think it's worn diff clutches
                        • 87-325ic
                          • Apr 2006
                          • 1198
                          i should check my fluid, it hasnt been as noticeable since my fluid change, but the last few months it sounds kinda like i took my rear seat out, just a bit louder you know?
                          nothing bad sounding yet..
                          • Wh33lhop
                            • 11705
                            Kinda.
                            It is, but try disconnecting your rear sway bar. Should help (unless you've got really stiff suspension and your rear sway is stock).
                            Go ahead and check your fluid.
                            paint sucks
