So yesterday i replaced the calipers, pads and rotors, ive done this countless times and know how to bleed the brakes....so its not something im unfamiliar with.
So i had my friend pump the brakes as i was the one under the car to make sure it was done the way ive always done it, usually i go around twice but it was too cold so we did each caliper once in the correct order. The pedal was hard as a rock like normal after bleeding, so i go to start up the car and its spongy, i drove up and down the street hammering the brakes and they barely do anything, so i drove home (night with no traffic) and then my brakes work a little better but i still cant lock the brakes up even with left foot braking (ABS sensor bad so ABS dont work). If i cant lock them up in the wet, with flooring the pedal then something is wrong, i have maybe 50% of normal braking force at best.
Could there still be air in the system? The reservoir was always topped off and never went below well....it didnt really move at all.
Any help is appreciated.
