Hesitation/Misfire Problem? Help
  • OOMPH!
    • 3487
    Just bought a 1989 325is. Trying to diagnose a hesitation problem and need some suggestions/advice. If you accelerate slow the car responds fine, however if you get on the gas hard the car will hesitate. Instead of a gradual increase of power it hesitates and feels very choppy like it's skipping. Already swapped an AFM so ruled that out. What else could it be?
    Thanks for the help in advance!
  • e30s52
    • Oct 2007
    • 5235
    Possible a bad ground.
    www.gutenparts.com
    • mrsleeve
      • Mar 2005
      • 16387
      FPR, Fuel Pressure (aka pump), TPS, CPS, plugs, how bout some more to work with
      Originally posted by Fusion
      William Pitt-
      • structured
        • 954
        Check in the M20 section. This has been discussed alot.
        I had a misfire which ended up being the harmonic balancer (vibration damper): http://www.r3vlimited.com/board/showthread.php?t=147102
        • KillaCam
          • 2103
          O2 sensor I had this prob. is it like giving and taking
          Originally posted by E30_(1st Musk)_
          HONDA IS WHERE EVERY TREND DIES! .
          24v swap Oil Pan..F/S
          • E30SPDFRK
            • 5715
            Could be a weak coil too
            Byron
            Leichtbau
            • mrsleeve
              • Mar 2005
              • 16387
              yes it could be, but since its fine under light acell, and light loads, I am going to lean to a fuel demand/delivery issues 1st.
              William Pitt-
              • barry
                • 1642
                Its a fuel problem, filter,hoses, injectors, vacuum, throttle body, idle adjustment, Fuel pressure, pump, Other- rotor, distributor cap, plugs, plug wires arcing.
                Good luck
                Barry
                • OOMPH!
                  • 3487
                  Distributor cap and rotor has been changed but the problem is still there. The plugs look good and fairly new. The O2 sensor looks on the new side. If it was a fuel related problem wouldn't it do it during all acceleration? This problem only occurs when you step on the gas hard. The car idles very smooth too. I still have to check all the other things you guys mentioned! Thanks for all the suggestions so far!
                  • xwill112x
                    • Jan 2009
                    • 4236
                    nope. WOT will make fuel issue's WAY more apparent. i would check the cap and rotor if it were me tho.
                    • bmwE30/541
                      • Oct 2009
                      • 135
                      plugs wires coils..
                      • mrsleeve
                        • Mar 2005
                        • 16387
                        Nope the fuel demand at heavy and WOT is way more than light acell. SO it will show up there 1st
                        William Pitt-
                        • Huff
                          • 2488
                          Check your main engine ground. Make sure the contact point isn't rusted (if it's doing under hard decelation too). Otherwise, it could be your intank fuel pump (the main one).
                          • OOMPH!
                            • 3487
                            I forgot about this thread.....You were right. The previous owner put the wrong plugs in and the wires were bad. ;)
