Coolant on Driver Side Carpet - Hmmmm
  • Atreus
    • 1846
    So.... I've been having a coolant leak since i completed my HG/Timing belt job.... i believe i have it tracked down to the throttle body. But, today, i get in my car to leave work, and the driver side carpet is sopping wet. sweet, stinky, coolant everywhere.
    now, i thought i bled the system properly, there were no leaks under the carpet, until i ran the vent/blower system on "cool" it was the first time i've done it, and i believe that may have a hand in this happening.
    There are no streaking wet spots on the center console/by the pedals, it is purely at the bottom of the carpet, like where the rubber foot part is in the carpet, to the front of the seat.
    bad heater core? its still blowing out hot.
    the two lines in the firewall by the brake booster?
    i read something about a valve by the heater core, could it be that?
    these things; i do not know.
    ///similar thread.
    any help is appreciated.
    89' 325i....
    1991 325iC - Mauritsblau sumthin metallic blue. DEAD
    1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
    1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
    1991 325iC - Calypsorot Metallic
    1994 540i - Granitsilber
    Originally posted by scabzzzz
    I've had blunts cock in my mouth, but I'm not gay.
  • bmwsun
    • 388
    i had the same problem and it was the two lines after the firewall... check to see if the valve is leaking.
    M3 springs w/bilstein hd's, IE 22/19mm sway bars, front IE stress bar, complete suspension rebuild, IS interior.
    Crew chief for BBQ2U Racing: James Crivellone, John Parker, Chris Anderson, Ben Wilson, George Howe, Will Kellog, Jim Cissell
    BBQ2U Racing, Best of Intentions Racing
    • Ral
      • 1486
      happened to me too. Best thing to do in my opinion would be to bypass the heater core entirely with a small piece of 1/2" fitting in the engine bay. (hell, summer will be here soon)
      sigpic89 M3
      • ck_taft325is
        • Sep 2007
        • 6880
        Def. check the valve there as "bmwsun" said. My friend had a similar issue when he bought his e30 and it turned out to be that.
        Need a part? PM me.
        • mrsleeve
          • Mar 2005
          • 16389
          valve, hose or core
          Originally posted by Fusion
          William Pitt-
          • Atreus
            • 1846
            okay cool, thanks for the leads guys. i'ma check the heater core DIY thread.
            • Atreus
              • 1846
              http://www.realoem.com/bmw/showparts...14&hg=64&fg=15 - is it #16 the valve you all speak of?
              # 4/5 are the two hoses that pop out through the firewall right?
              • Atreus
                • 1846
                and last question, in the meantime, to reduce the soaking carpet/leakage, do i just keep the heat off?
                • StereoInstaller1
                  GAS
                  • 22679
                  Texas, meet Colorado.
                  Check that the hoses aren't leaking down the outside of the coolant pipe and dripping from there, too. Unlikely as the seal is good and tight, but WTF, it is 20 years old, right?
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • gearheadE30
                    • Jun 2007
                    • 3734
                    the valve by the core is an overpressure bypass valve because apparently e30 heater cores have a tendency to explode if the car overheats badly. It was a recall item that was often poorly installed. Check that and the pipes on the heater core inside the car; I bet it's one of those.
                    Project M42 Turbo
                    • 325ix
                      • Aug 2009
                      • 7783
                      Ha I wish I got another three months
                      • evil_twin
                        • Nov 2007
                        • 2965
                        Sounds like the heater valve. I had that problem, and did bypass the heater core for a year or so. If you do that, remember to put the lines BACK where you got them from or else you won't get heat anytime over 3k.
                        Paypal: vdang5@gmail.com
                        Delta Auto Care
                        2875-C Towerview Road
                        Herndon, VA
                        703.435.1375
                        My Feedback Thread: Evil_Twin
                        • StereoInstaller1
                          GAS
                          • 22679
                          No, the bypass is near the block. That valve simply shuts off the water flow...it is opened and closed by the temperature control switch.
                          Whoever suggested that was to prevent heater core failure is full of crap.
                          Closing SOON!
                          • Atreus
                            • 1846
                            going to try my luck at the junkyard today..... cold denver mornings suck ass. driving around in my onesie is horrible, hahahaha.
                            • Atreus
                              • 1846
                              pulled the carpet out, was gonna do a write up, but once i got to the gas pedal/carpet removal part, i said fuck taking pictures.
                              got it out, warming up the car to see where this leak is coming from. put the seats back in. need to figure out a good way to dry the foam.... any pointers there? the carpet is sopping wet. ugh.
                              to top it off, i found some surface rust under the tar under the carpet. i removed the tar, what is the best way to deal with the rust? never dealt with rust before. can i wire brush it off, clean it, and spray some rustoleum on it? lol
