What to buy when replacing fuel injectors?
  • Surtr
    • Nov 2008
    • 177
    I am looking to replace my fuel injectors, but I am looking for advice on what to replace them with. I have a stock M20B25. I tried checking eBay for rebuilt injectors at a stock flow rate but could not find anything. I only see 19lbs injectors. My main concern with those is running too rich. I have seen differing opinions on them. Some people claim they will run too rich, some people say the ECU will adjust the duty cycle. I'm also afraid that the sellers on ebay have not really flow tested the injectors or even checked they are working. I guess my other options are to buy used stock injectors (where?) and send them out for cleaning, but that will likely cost more than the 19lbs injectors off eBay and they may not be flow matched.
    So, would the 19lbs injectors be fine in my engine? Keep in mind I'm in CA and barely pass smog as it is (but I believe part of this may be due to shitty injectors). Does anybody know a reliable seller? Or should I try to get injectors with a stock flow rate? Is there a source of already cleaned, rebuilt, tested and matched stock injectors? Any help is appreciated.
    '07 Female Miniature Dachshund, Long Hair Edition, Red.
    Mods so far: Reproduction delete kit, biweekly nail shortening.
    (Pics hopefully coming soon)
  • hugh jass
    • 2220
    guy is awesome
    ______________________
    ex-Chief Operating Officer
    Blunt Tech Industries
    West Coast and Pacific Rim
    • Surtr
      • Nov 2008
      • 177
      Yeah, that's who I'd use if I bought stock injectors and who I used to base the price off of. Unfortunately I do not have the option of sending in my current injectors and having him send them back, as the car is my DD.
      • dannyg
        • Mar 2007
        • 1553
        Check here, there are always people parting out cars. Should be able to find a set of injectors for fairly cheap. Then you can send them out to have them cleaned and tested.
        1993 325ic Schwarz/Natur
        1991 318is Black/Black - Slicktop - Project s52
        1989 Alpine White/Black M3 S52
        1988 Henna/Pearl M3 <3
        • Surtr
          • Nov 2008
          • 177
          Yeah, the problem with that is I might get a bad one and it'll end up costing more and take longer. I kinda feel fucked either way.
          • Surtr
            • Nov 2008
            • 177
            Crap, does anybody know what is better? The yellow injectors with 4 holes, or the one with 1 hole and a ribbed pintle cap?
            • dannyg
              • Mar 2007
              • 1553
              On my convertible I just serviced the injectors and they had 1 hole with the ribbed pintle cap. I picked up a kit off ebay that had new caps, filters, o-rings and spacers. For a kit of 6 it was $24.
              • Surtr
                • Nov 2008
                • 177
                Yeah, I looked at doing that too. The problem is one of my injectors is leaky and that doesn't ultrasonically clean and flow test them. I think I'm going to buy 19lbs injectors and if they suck ass or cause me to fail smog, I can at least use them until I can get my current injectors cleaned / replaced. But now there are 2 different types of 19lbs injectors to get.
                • ak-
                  • 12422
                  Type 3's.
                  1991 325iS turbo
                  • Surtr
                    • Nov 2008
                    • 177
                    Originally posted by ak-
                    Type 3's.
                    Which are those? I think I've only seen design I and II.
                    • ak-
                      • 12422
                      19lb Bosch Design III.
                      edit: http://losangeles.craigslist.org/lac...579550535.html
                      Grab these before I do.. Seriously.
                      1991 325iS turbo
                      • T Verdier
                        • Aug 2007
                        • 2636
                        I couldn't find one! who was the seller?
                        • Surtr
                          • Nov 2008
                          • 177
                          Oh wait, Design III is the type with 4 holes? I found some on ebay, hopefully from a good source.
                          http://cgi.ebay.com/ebaymotors/Fuel-...Q5fAccessories
                          The only other ones I see are from somebody named smokestackj and I seem to recall reading a post on here that his stuff sucked.
                          • dannyg
                            • Mar 2007
                            • 1553
                            Heres a link to the sellers store:
                            • Surtr
                              • Nov 2008
                              • 177
                              Actually, I've read the 17.5lbs from an M50 are much better suited to a stock engine. You're better off getting those. Apparently 19lbs injectors only work well in cars that have vacuum leaks or upgraded intake.
