uh oh?
  • Chabs
    • Jan 2010
    • 538
    uh oh?
    my car is in the garage for the winter and the battery died. the car really doesnt like the cold. i was just outside giving it a boost to start it up and have it run for a bit. it ran fine once the battery got enough of a charge, but when i unhooked the booster cables, it stayed on for about 20 seconds and turned off. is it just the fried battery not holding a charge? or something else? should i be worried?
    Josh
    http://www.r3vlimited.com/board/showthread.php?t=159843
  • Wh33lhop
    • 11705
    Your alternator is most likely dead. Take it to autozone or something and have them check it.
    paint sucks
    • wodcutr
      • Apr 2009
      • 2193
      How muck voltage did your battery test at?
      The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
      • damith
        • 422
        Wh33lhop is correct. It sounds like your alternator is done. Same thing happend to me and turned out to be dead alternator.
        [All the Bronzit haters]
        • Fidhle007
          I can fly, motherfucker
          • Oct 2005
          • 7209
          Definitely a dead alt.
          '89 325is S50 Track Montser
          '04 X5 Daily/Tow Vehicle
          http://www.avarestoration.com
          http://www.myspace.com/brendanfiddle
          Click here if you want to be my zombie slave...
          http://www.youtube.com/user/Fidhle007
          • AndrewBird
            The Mad Scientist
            • 11897
            You should NEVER run a car on just the alternator and a dead battery. Overloads the alternator and kills it. This is likely what happened. Charge the battery with a charger first, then put it back in the car.
            • Chabs
              • Jan 2010
              • 538
              thanks guys, but I don't know how it could be the alternator. The car turned on fine 2 weeks ago, it was idling for over half an hour and I took it for a quick drive around the neighbourhood. I took the battery out and put it in my furnace room to warm up, its been pretty cold out lately. I'm really hoping its just a cold-ass battery
              Josh
              • Joe318is
                • Sep 2005
                • 6451
                Have them checked before doing any big purchases.
                If the battery is super low it will take a while for the charge to come up. Ive seen cars run on 7.5v before [91 318is, so dont get fancy] Did not run well, but it would sit and idle.
                Im willing to bet that it is not the alternator, but a slow draw on the battery. Mainly because you had it running for 30+ minutes
                Originally posted by vlad
                • Chabs
                  • Jan 2010
                  • 538
                  thats also what im thinking, it was running really well two weeks ago, just in the past week or so its been almost down to -20 at some points.
                  Josh
                  • barry
                    • 1642
                    Batteries go dead when sitting.. Best thing is taking battery from car and setting it on a thick piece of wood and keep it charged.
                    Get a new battery..
                    Good luck
                    Barry
                    • whatt18yahoo
                      • 619
                      charge the battery put it in the car start it good luck
                      if that fails take battery and alternator to test
                      • TexasTerp
                        • Jan 2009
                        • 3541
                        To beat a dead horse at this point. If you're gonna garage a car, then take out the battery and put it on a charger! Go get your alternator checked at Autozone.
                        stephenbrody.com
                        • Fidhle007
                          • Oct 2005
                          • 7209
                          It's the alternator. If it wasn't, the car would run even with the battery disconnected. Seriously people...
                          • Wh33lhop
                            • 11705
                            Get a new battery..
                            Good luck
                            Barry
                            Do not go out and blindly get a new battery. Have the original one TESTED and see how many CCA's it's putting out.
                            The battery is not your main problem. We've already told you what to do, now go do it. Worst case, you waste 20 minutes and your alternator still works.
                            paint sucks
