power steering delete..
  • 87-325ic
    • Apr 2006
    • 1198
    how do i go about running no power steering while leaving the pump in place? just take the belt off?
    and if i really wanted to go power-less, should i remove the pump and do the block off mod thing?
    if i were to do that, i just plug each line in the rack, or should i connect them? (cut hose and clamp in a coupler.)
    Thanks.
    ps, whats all the jive about draining the liquid out of the rack replacing it with grease?
  • Philo
    Ich esse kleine Kinder
    • 3334
    You can leave the pump in place if you would like; Removal is optional. If you simply remove the belt it will be very rough and almost impossible to drive. To run without PS you want to remove the lines, and loop the in/out. You can buy a PS delete block from "Silence" or you can jerry rig a loop line. Either works. It is necessary to drain most of the PS fluid in the rack, as pressure will otherwise build up as the rack reaches lock: making it harder to turn. I leave just enough PS fluid to lubricate the rack. The grease that Mentaleeill or someone did was to lube the rack in a different way. I have not tried this, so I can not speak for it. PS fluid will work fine though.
    It's slightly tricky to loop the lines, as you will be using banjo bolts but it is possible if you know what you are doing.
    -tim
    Originally posted by Jordan
    I like the stance
    • AC Nico
      • 3619
      or you can just buy a non power steering rack. :)
      i have one left for sale.
      *** For sale: euro stuff, BBS steering wheels, smoked tail lights, bunch of rare wheels (5x120 and 4x100) ***
      [/color]
      • 87-325ic
        • Apr 2006
        • 1198
        well the reason i ask is because im about to go put on my 95 m3 rack, and my pump has been making some noise lately. i just worry that ill find out it has a worn shaft or something and i wont want it back on...
        or for some stupid reason i cant get the rack hosed to the pump or something.
        how exactly do i know how much oil to drain out? and what could be too hard about connecting the hoses in loop? they wont be seeing any pressure..
        • evoDRichie
          • Jan 2010
          • 1743
          when looping the in/out fittings with PS fluid in the rack still, will it be as if u still had PS? easy to turn?
          • 87-325ic
            • Apr 2006
            • 1198
            im searching now, cant sleep..
            apparently its as easy at high speeds, but hell at really low.
            • der affe
              Technical
              • Dec 2005
              • 8452
              i have a93 m-3 rack with one of silence's delete block off's. i went from a severly leaking std E-30 rack to the M-3 rack and it was a little stiff at first because i was used to the p/s rack, but after a week of so i was used to it and i would not go back.
              you will also notice a power gain down low when you remove the p/s stuff.
              just delete the p/s with silence's block and drive happy.
              • decay
                • 5637
                it's a small incremental gain. delete the PS, delete the AC, and replace the clutch fan with an electric one all at once and you will actually notice something significant.
                past:
                1989 325is (learner shitbox)
                1986 325e (turbo dorito)
                1991 318ic (5-lug ITB)
                1985 323i baur
                current:
                • 87-325ic
                  • Apr 2006
                  • 1198
                  after some searching, i found all the info i could ever need.
                  now im wondering what snag ill run into with the rack swap coming up as soon as the sun does.
                  im going to shoot for hooking it back up, but if things look easier, i might try the delete.
                  i have to swap racks, and brake master cylinders, im doing it at the same time b/c it might give me more steering knuckle accessibility. then go get new tires put on and an alignment. i hope i can get it all done today.
                  • evoDRichie
                    • Jan 2010
                    • 1743
                    looks pretty easy with this...
                    • Lurker27
                      • 821
                      Yep, just buy the delete it makes your life SO easy.
                      '89 335is +turbo
                      • ZombiE30
                        • Dec 2009
                        • 438
                        The delete that Silence sells is a work of art.
                        No hoses, no pump, no reservoir=space to actually work on shit (and NO BLOODY LEAKS).
                        Originally posted by stoliver54
                        Aw, balls.
                        FS: assault gear....
                        http://www.r3vlimited.com/board/showthread.php?t=159253
                        • 87-325ic
                          • Apr 2006
                          • 1198
                          it looks like looping the hoses would be just as easy... but this plate would make it really pretty.
                          • b*saint
                            • 3794
                            Why would you want to do this? To save 30 pounds?
                            Ma che cazzo state dicendo? :|
                            • ethree
                              • Aug 2007
                              • 1216
                              Saving 30lbs, saving the parasitic loss of the ps pump and the power steering on these cars is really unnecessary. Even if you just pull the belt at first it's not difficult to drive unless you spend a lot of time in parking lots and/or parallel parking.
