Need help with my e30 problem!
  • matias88e30
    • Dec 2009
    • 1110
    i dont know wtf is wrong with my e30 is an88 325is, everytime i start the engine it seems like it want to turn off and if i hit the gas pedal once its even worst the car will choke and most of the times will turnoff and then to start the engine again its a pain in the ass, i replaced some hoses a few weeks ago due to a vaccum problem and the car was working perfect till a few days ago, also when the engine its running you can smell like all the gases the engine produces, should i check for other vaccum leaks? i don know what to do so any help or advice would be aprecciated! thanks
    no more boosted m20, 91 318i...
  • browntown
    • Jun 2004
    • 3524
    extreme exhaust leak? how's your oil level look? is the oil cloudy at all? can you smell unburnt gas in the exhaust? Check all your plug wires and ignition components?
    You can buy a vaccuum gauge at harborfreight for cheap to make sure you don't have a leak anymore.
    • mbulsa
      • Oct 2009
      • 313
      this happened to a friend of mine recently and he had a massive hole in one of his hoses, im not 100% sure thought, good luck with the problem though.
      • matias88e30
        • Dec 2009
        • 1110
        the smell is like unburn gasoline or some kind of gases, i removed the complete exhaust system yesterday in order to check any cracks or damages and it wasnt, oil level look perfect
        • Will_318i
          • Jan 2010
          • 482
          Originally posted by whatt18yahoo
          (this is odorless so unless you're a german shephard you're not smelling this)
          I LOL'd...
          "get in, get off, wipe your dick off on her sheets and get out."
          • IDM
            • 754
            Check the injectors might have a sticky one.
            • JTapper
              • Sep 2009
              • 847
              you need to clarify the gasses you're smelling are we talking about gasoline? or carbon monoxide(this is odorless so unless you're a german shephard you're not smelling this) please clarify
              Please don't try to give people advice.
              Seriously.
              You can't even tie your own shoes.
              Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
              • matias88e30
                • Dec 2009
                • 1110
                thanks for the advices, i let yall know what happens,.. you might be right i cant even tie my shoes but im sure your momma will be glad to teach me
                • matias88e30
                  • Dec 2009
                  • 1110
                  i replaced the injectors with ford taurus sho's. The car worked perfect till now so thanks for the help
