driveshaft help!!! Need to finish this tonight please help!!!!
  • ediaz029
    • 75
    I am replacing my trans and have it mounted and everything I am to the point of putting the drive shaft back on and it does not reach!! when we were removing it it was almost to tight I put in an lsd as oppossed to the 4.10 open diff I had before and the lsd I put in is actually bigger than the old one. I really need some help anything is appreciated!!!!! I need to finish this tonight!!!
    Thanks,
    Kevin
  • White325is
    • Oct 2006
    • 5947
    the drive shaft will extend. You need to loosen the nut behind the CSB.
    Changing the LSD isnt going to change the length of your driveshaft.
    • ck_taft325is
      • Sep 2007
      • 6880
      *EDIT*
      Nevermind.
      Need a part? PM me.
      • ediaz029
        • 75
        what is the csb?
        • ediaz029
          • 75
          ok but there is no play with the drive shaft though we have those two bolts lose it just isnt moving
          • ck_taft325is
            • Sep 2007
            • 6880
            WD-40 might be your friend here.
            Need a part? PM me.
            • ediaz029
              • 75
              but where I dont understand where I should be getting play from the drive shaft is completely extended where am I missing that it will move from
              • ediaz029
                • 75
                bump I need this fixed tonight or I dont go to class tomorrow
                • Naplm00
                  • Nov 2008
                  • 1573
                  the big center collar nut behind the CSB or "center support bearing" ...aka that thing in the middle...it is threaded to the splined center section
                  Loosten that fucker and extend or lengthern the shft as needed
                  88 325ic ~~~> Rusty and ugly
                  85 E ~~~> RIP
                    • 37832
                    Installation is the reverse of removal. :)
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • pogiboy9
                      • 475
                      Don't have your Bentley manual ?
                      http://www.decal-spec.com
                      • 87-325ic
                        • Apr 2006
                        • 1198
                        look at the bright side... you dont have to go to class tomorrow.
