25mm or 1' sway bar bushings
    I am in need of some bushings for the sway bar I've made. I'd like to order them as soon as possible. So does anyone make larger bushings that will fit in the stock carrier?
    Have any of you used the bushings IE has with their carrier? I don't know anything about it, and it appears that it does not mount the same as the stock one does. I searched to try to find some info on it and couldn't find anything.
    Any input would be appreciated.
    Bumping? I've looked at the stock bushing carriers and it looks like they'll be a little small for the larger bushings. I can make new carriers, but I'd rather buy them. I need to get them soon because I will be having them zinc plated.
    So anyone have any insight here?
      you need to get the whole bushing and carrier, works great though. just be generous with the lube if you dont want it to have it start creaking every second.
      how'd you do the bar ends after all?
        I have no input but I thought your title was funny because there are 25.4mm in an inch
