Backseat Tar
  • craiggroves91
    • Oct 2009
    • 3024
    Backseat Tar
    Sorry if this has been discussed in various threads, but it is hard to search and find stuff about it.
    I already have removed the trunk tar and that was 52lbs.
    I have a street car, but of course I want my car the fastest it can be. I was wondering If I took out the tar under the backseat if there would be too much road noise coming in?
    The backseat seems to block all the noise, and I could always dynomat or something later on. I want to clean it up under the back seat, its all fugly and heavy haha
    thanks
    Craig
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
  • lennon
    • Jun 2008
    • 1416
    if youre asking, maybe you shouldnt take it out. but really, it wont be loud just because you remove that under-seat insulation. you especially wont notice if your car is already loud.
    edit- and if i were you, id wait till summer or atleast a hot day to take it out. makes it a lot easier once its warmed up.
    • Will_318i
      • Jan 2010
      • 482
      won't the dynomat add weight back into the car?
      "get in, get off, wipe your dick off on her sheets and get out."
      • E30 Wagen
        • Jul 2005
        • 3429
        removing trunk tar is completely unnecessary
        /thread
        edit: this has been covered a thousand times. Search
        My Feedback
        • craiggroves91
          • Oct 2009
          • 3024
          Isnt dynomat fairly lightweight?
          Removing trunk tar isnt necessary or unnecessary, Its whatever
          let it happen
          1989 BMW 325i SOLD
          • xwill112x
            • Jan 2009
            • 4236
            i did it. as long as the back seat is in, it isn't to bad. be sure to use a heat gun to get it up though, otherwise its a pita.
            • StereoInstaller1
              GAS
              • 22679
              The trunk tar is there to achieve a proper weight balance, it does virtually nothing for noise.
              Craig, did you notice a difference with the 50ish pounds out?
              Closing SOON!
              Thanks for 10 years of fun!
              • xwill112x
                • Jan 2009
                • 4236
                while mine was gutted, i noticed in my 318 a difference around corners. it was more predictable when sideways aswell.
                • StereoInstaller1
                  GAS
                  • 22679
                  You had a 318 that had trunk tar? I have only seen it on 6 cylinder cars
                  Closing SOON!
                  • calz4m
                    • Aug 2009
                    • 96
                    There is no reason to remove the backseat "tar". It doesn't weigh a lot. Most E30s that are turned into race cars or track cars leave it alone. Absolutely unnecessary on a street car.
                    • xwill112x
                      • Jan 2009
                      • 4236
                      it had sound deadening that the po had installed back in like 93'.
                      edit: it wasn't tar, but huge heavy rubber mats that covered the trunk, that were doubled up aswell.
                      • Streichholzschächtelchen
                        • Jan 2009
                        • 1670
                        Remove it if it bothers you, but it's paper thin. I did it just to be consistent as I was gutting everything anyways. Use a small chisel and a heat gun or else you're going to be there for a while. I think I got a grand total of 15lbs out of the interior without going behind the heater core and exactly 50lbs in the trunk, weighed it.
                        Jah bless! :pimp:
                        • Naplm00
                          • Nov 2008
                          • 1573
                          I dont beleive this statement, for real?
                          88 325ic ~~~> Rusty and ugly
                          85 E ~~~> RIP
                          • Mike325
                            • Mar 2006
                            • 3685
                            I took the trunk tar out of my car and it was a bad idea. The stance of the car was off and the rear end felt way too light and loose. I ended up putting some weight plates in the spare tire well to make up for it.
                            Leave the tar in, change your air filter if you want that ounce of more power.
                            Originally posted by Kershaw
                            • StereoInstaller1
                              GAS
                              • 22679
                              Closing SOON!
