window install
    window install
    im sure there is a write up about how to install a quarter window in an e30 coupe, but i can't seem to find it. i need to put new glass in the window behind my passenger door.
    thanks
    pop out or not pop out?
    pop out is easy, there are two 10mm (iirc) nuts behind the b-pillar, they hold the forward/front section of the glass to the body.
      its a pop out. thanks.ill go try that
        ok, so the hook on the top of the b-pillar is giving me problems, i really don't wanna break it, is there an easy way get it off?
          You remove the screw, and then pull on it.
            ok, thats what i thought, i just didnt want to break it.
