Accu-sump
  • 619E30
    • 1753
    Accu-sump
    Anyone ever had experience with an accu-sump?
    Originally posted by audiquattrot
    bimmers b4 b*tches....remember that.
    1990 Alpinweiss 325i - secret 500whp build
    2000 Audi S4 B5 Laser Red
    1990 Nissan 240sx - Drift Missile
    2006 CBR600RR
  • Emre
    • Sep 2007
    • 1228
    I've got a 3qt set-up going in my E30 track car. What do you need to know?
    1987 Mercedes 190E 2.3-16: Vintage Racer
    2010 BMW (E90) 335xi sedan: Grocery Getter
    • george graves
      • 19996
      Do you have a pressure gauge as well? Guess I'm asking if you can "see" it working. Hope that's not a thread jack.
      Originally posted by Matt-B
      • Tom Olsson
        • Nov 2009
        • 12
        Had one on a former race car. It was effective at keeping the oil pressure up in the corners, but was a PIA, as inevitably you'd pull into the pits and realize you haven't shut the valve. Gotta rev the motor to get all the oil back into the sump, shut the valve, then shut down the motor. We ended up pulling it out when we found an effective oil pan baffle. With the baffle, I've never seen less than 50# of pressure in the corners.
        '88 M3
        '87 325is #55 Pro3
        • erik325i
          • Jan 2005
          • 3567
          I have a 2qt one in my M3. I like it.
          Erik
          • Rigmaster
            • 3464
            You had the manual valve version then?
            You can get one with an automatic valve that you hook up so it closes the valve when you turn the engine off- that way you maintain pressure in the Accusump so it helps next time you start the car.
            FWIW, even a 3 Qt system is only gonna provide a couple of seconds of pressure at high RPM's- but even that little bit extra can help mean the difference between engine damage and none.
            But a good pan baffle is a good idea too- and cheaper than an Accusump.
            • 619E30
              • 1753
              So it would be a good investment?
              2006 CBR600RR
              • erik325i
                • Jan 2005
                • 3567
                It can't hurt to have. I like the having the extra protection from oil starvation.
                If you consider the cost of the all the fittings and lines, it's not as cheap as it seems though.
                Erik
                • Emre
                  • Sep 2007
                  • 1228
                  I spent a lot of time talking to the people at Canton when I was setting up the system in my E30 track car. So maybe I can offer some "inside" info.
                  You had the manual valve version then? You can get one with an automatic valve that you hook up so it closes the valve when you turn the engine off...
                  They absolutely do NOT recommend the electronic valve for track use. They say it reacts too slowly to prevent oil starvation. It was designed for pre-oiling only. For track use, they say only the manual valve will work.
                  I guess it depends on how you define "a few seconds." According to the guys at Canton, the 3qt system hooked up to an M20B25 will maintain oil pressure for at least 20 seconds at max rpm...and probably closer to 30 seconds. That's far longer than it will take you to get through even the longest sweeper you'll ever come across.
                  Depends. Paul Poore charges over $600 for an M20 baffled oil pan. My complete Accusump setup wasn't much more than that.
                  If there's a cheaper source for a baffled pan, I'd like to pick one up. Between the Accusump and baffled pan, I think we should be OK.
                  • guibo09
                    • Dec 2008
                    • 834
                    which baffle are you using?
                    90 E30 325i
                    • booostit
                      • Jul 2009
                      • 224
                      are the IE baffle trays any good?
