testing crank position sensor
  • iwantspeed
    • 3164
    just trying to test the cps sensor and not sure if I did it right
    which terminals are you suppose test
    and is the value suppose to be 540ohms?
    Project
    Parts for Sale
    Feedback
    YouTube Channel
  • evil_twin
    • Nov 2007
    • 2965
    TESTING PULSE SENSOR
    Disconnect the electrical connector. Using an ohmmeter, check the resistance between terminal 1 (yellow wire) and terminal 2 (black wire) on the sensor side end of the connector. If the resistance is not approximately 520 ±5 ohms, the sensor is faulty and should be replaced. Remove the sensor mounting bolt using a 5 mm hex wrench. When the sensor is installed, the distance between the sensor tip and the toothed wheel should be 1.0 ±0.3 mm (0.04 ±0.01 in.). Tighten the sensor mounting screw to 7 ±1 Nm (62 ±9 in.lb.) . Be careful not to overtighten the mounting screw. Be sure the wiring is correctly routed through the protective covering.
    -Taken from Alldata
    Paypal: vdang5@gmail.com
    Delta Auto Care
    2875-C Towerview Road
    Herndon, VA
    703.435.1375
    My Feedback Thread: Evil_Twin
