intake clearance
    intake clearance
    if i use the e30 motor mounts on the m50 swap does the motor sit to low so the intake does not clear the brakebooster? i have the thr booster so its the right diameter. if i use the aluminum e36 mounts will it give the motor enough lift to have the intake clear the booster
    holes wont line up with bolts.
    -Dan
