I had a chunk of thought dedicated to this for the last 5 minutes, how possible would it be? I mean if it consists of replacing once a year or so or modifying it to be able to withstand motor oils and more aggressive water based solvents (seals, hoses, shit like that which could go deteriorating) its still cheaper at $25-50 for a used unit rather than a $3000 commercial grade heated parts washer. No harbor freight junk...Ive already tried that and by itself it sucks.
dishwasher to heated parts washer conversion?
Tags: None -
Thats what I'm thinking. found a white maytag for $25 in santa monica. Mayb i go try.Comment
any progress?Renting my rear wheel bearing tool kit. SIR
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Some guys from 2002faq.com did exactly what you are talking about. And the "dishwasher method" worked great on stuff such as heads... Just make sure your soap is compatible with aluminum...Brake harder. Go faster. No shit.
massivebrakes.com
35 gallon drum with 10 gallons of simple green "crystal" mixed with water, used closed loop?
A 5 gallon bucket of crystal is about $70
If you drew from the bottom of a bucket would you need a pump? Would gravity be adequate if the drum were on top of the machine? I bet it would kick ass...Comment
