Calculating weight distribution
  • noid
    • 1537
    Less weight is good and all but we all know the e30 gods want balanced weight loss
    It seems the best way to do this would be to take 4 separate scales and put them under each tire. That way you can calculate weight distribution front to back and left to right.
    Problem is where would someone find scales small enough to fit under 1 wheel but also be strong enough to read as high of a value (~700lb per wheel)?
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
  • e34john
    • Apr 2006
    • 3599
    Go to a race shop that does corner balancing. You won't be allowed to adjust too much unless you have coil overs but they will be able to give you the weight of each corner.
