Power steering (might ditch it)
  • craiggroves91
    • Oct 2009
    • 3024
    Hey guys. So when I bought my car recently i knew it had a PS leak. The power steering hasnt been working the majority of the time I have owned the car. I have been fine without it. So I bought some ATF fluid filled up the reservoir and it was working fine. It began to LEAK LIKE CRAZY.
    I decided I dont really need it. How much does it weigh? should I fix it or just ditch it?
    I dont mind getting rid of it.
    Also I am a noob so I need help getting rid of it. How hard is it?
    Do I just unbolt the mounts for the PS and buy one of these?
    http://r3vlimited.com/board/showthread.php?t=130389
    thanks
    -Craig
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
  • rThor432
    • Feb 2007
    • 3907
    Yes. You can even cut the belt if you want to be the ultimate slacker.
    • craiggroves91
      • Oct 2009
      • 3024
      1989 BMW 325i SOLD
      • Naplm00
        • Nov 2008
        • 1573
        just got rid of mine today with a euro manua rack, its awesome
        88 325ic ~~~> Rusty and ugly
        85 E ~~~> RIP
        • iamsam
          • Jun 2008
          • 174
          OP: what motor is in your car? if its an M30 for example, you may want PS. But I ditched mine, and I'm never going back!!
          First of all, you don't need a machined delete block. just drain the rack and plug the holes like I did in my thread below.
          here's my thread, take a look: http://www.r3vlimited.com/board/showthread.php?t=162329
          • AlarmedBread
            • Sep 2006
            • 1510
            You want to have a loop in the PS lines coming out of the rack, you can either loop a hose or use a block with passages in it.
            To see if you can live with it, just take the belt off for a while, it'll leak a lot less and you can decide if you want to fix it or toss it.
            • AndrewBird
              The Mad Scientist
              • 11898
              I would first determine what is leaking. If it is a just a hose, that is a simple cheap fix. If it is the rack itself, that is another story.
              And draining the rack and running it dry seems like a really bad idea. Just because you aren't pushing fluid through it doesn't mean it doesn't need lubrication. All the people I've heard that have ditched the power part have just topped the rack off and plugged the two holes or looped a line across them.
              • MvancE30
                • 138
                why would you want it if its an m30?
                • craiggroves91
                  • Oct 2009
                  • 3024
                  I have an M20. I havent had power steering the whole time ive owned the car with no fluid. No noise or problems. The belt should be on because it worked when i put fluid in. I have no idea whats leaking.
                  1989 BMW 325i SOLD
