i'm retarded!!! how do i use this power steering delete?
  • richardkeith97
    • 1693
    i bought that ps delete thing from silence and i have no idea where it goes? theirs more then 2 lines that go into my pump and i don't want to take ones out unless their he ones i need to. i want to use this and remove all of the power steering stuff. a little help please. maybe a pic of exactly where it goes and what hardware i need?
  • george graves
    • 20003
    Are you sure you should be working so much with your hands while your finger tip is healing?
    Originally posted by Matt-B
    • richardkeith97
      • 1693
      lol. i know everyone is conderned. i'm getting very good at doing things with my thumb and middle finger and keeping that finger out of the way. i put my component system in today and a new deck. i'll go crazy if i just sit around doing nothing
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        If it's the standard SS blockoff plate, it goes on the rack, not the pump.
        • richardkeith97
          • 1693
          ya thats what it is. i thought you used the bolts on the rack already and got new copper washers? i dont see where i have holes in my rack that are the same lengeth away as the ones on the block off plate?
          • richardkeith97
            • 1693
            is it that little plate on the drivers side of the car right behind the oil pan?
            • richardkeith97
              • 1693
              ooooooo i see where its supped to go. i thought it would have been easier to get to. i dunno if i can do that with my injury
              • Mike325
                • Mar 2006
                • 3685
                Take it easy man. Let that finger heal. It sucks now, but if it gets infected, all hell breaks loose and you will be out for a lot longer than is needed.
                Originally posted by Kershaw
                • ck_taft325is
                  • Sep 2007
                  • 6880
                  Yeah, that finger shouldn't be doing PS rack work. It's tight in there and usually a bit gnarly.
                  Need a part? PM me.
                  • richardkeith97
                    • 1693
                    kk i get the hint lol
                    • accident
                      • 7303
                      dude. your finger.
                      your finger dude.
                      dude. stop working on cars.
                      your finger.
                      dude.
                      Moral of this story?
                      • der affe
                        Technical
                        • Dec 2005
                        • 8452
                        i know where you are comming from, but be smart about it! put a plastic bag over the bandage and don't work anywhere you are going to be cramming your hand into tight, GREASY spaces. the p/s fluid will soak right through your bandages and on top of risking infection, if you go in to see the doc with grease all over your bandages he is going to flip out!
                        if you wrap it in a bag and change the bandages after, you should be ok for the most part, but use your head.
                        i have done this after each of my burn aurgeries and have not had a problem.
                        • 36brua
                          • 689
                          first off you're insulting a handicapped person with your retarded reference. So I guess since you are retarded, your reading and search skills are minimal which would explain why you had to start this thread . I love R3V :p
                          My CA legal M60 swap
                          The happening in our garage
                          • Rennsport
                            • 2139
                            what?
                            m106 1990 e30
                            e36 daily
                            e32 cruiser
                            • 2002maniac
                              • 4260
                              You're retarded as well?
