cool cars in history thread
    Chrysler Turbine car
    The fourth-generation Chrysler turbine engine ran at up to 60,000 rpm and could use diesel fuel, unleaded gasoline, kerosene, JP-4 jet fuel, and even vegetable oil. The engine would run on virtually anything and the president of Mexico tested this theory by running one of the first cars — successfully — on tequila. Lol Air/fuel adjustments were required to switch from one to another, and the only evidence of what fuel was being used was the odor of the exhaust.
    The engine[1] had a fifth as many moving parts as a piston unit (60 rather than 300). The turbine was spinning on simple sleeve bearings for vibration-free running. Its simplicity offered the potential for long life, and because no combustion contaminants enter engine oil, no oil changes were considered necessary. The 1963 Turbine's engine generated 130 brake horsepower (97 kW) and an instant 425 pound-feet (576 N·m) of torque at stall speed, making it good for 0-60 mph in 12 seconds at an ambient temperature of 85 °F (29 °C) — it would sprint quicker if the air was cooler and denser.
    The absence of a distributor and points, the solitary start-up spark plug and the lack of coolant eased maintenance, while the exhaust did not contain carbon monoxide (CO), unburned carbon, or raw hydrocarbons. Nevertheless, the turbine generated nitrogen oxides (NO) and the challenge of limiting them helped to kill the program.
    Kinda reminds me of the flux capacitor. I could just burn all my trash on the way to work. how cool would it have been if these were mass produced!
    Post up anything else you know.
    Speaking of...
    The Ford Model T, The first vehicle mass produced, and credited with the creation of the assembly line.
    Produced from 1908 to 1927, reduced build times from 12.5 hours per, to 93 min per.
      The Tucker Torpedo
      Many components and features of the car were innovative and far ahead of its time. The most recognizable feature of the Tucker '48, a directional third headlight, known as the "Cyclops Eye", would turn on at steering angles of greater than 10 degrees to light the car's path around corners. At the time 17 states had laws against cars having more than two headlights.[3] Tucker fabricated a cover for the cyclops center light for use in these states.
      The car was rear-engined and rear wheel drive. A perimeter frame surrounded the vehicle for crash protection, as well as a roll bar integrated into the roof. The steering box was behind the front axle to protect the driver in a front-end accident. The instrument panel and all controls were in easy reach of the steering wheel, and the dash was padded for safety. The windshield was designed to pop-out in a collision to protect occupants. The car also featured seat belts, a first in its day. The car's parking brake had a separate key so it could be locked in place to prevent theft. The doors extended into the roof, to ease entry and exit.The engine and transmission were mounted on a separate sub frame which could be lowered and removed in minutes with just six bolts removed—Tucker envisioned loaner engines being quickly swapped in for service in just 15–20 minutes.
      Tucker envisioned several other innovations which were later abandoned. Magnesium wheels, disc brakes, fuel injection, self-sealing tubeless tires, and a direct-drive torque converter transmission were all evaluated and/or tested but were dropped on the final prototype due to cost, engineering complexity, and lack of time to develop.
      Tucker initially tried to develop an innovative engine. It was a 589 in³ flat-6 cylinder with hemispherical combustion chambers, fuel injection, and overhead valves operated by oil pressure rather than a camshaft. An oil pressure distributor was mounted inline with the ignition distributor and delivered appropriately timed direct oil pressure to open each valve at the proper interval. This unique engine was designed to idle at 100 RPM and cruise at 250-1200RPM through the use of direct drive torque converters on each driving wheel instead of a transmission. These features would have been auto industry firsts in 1948, but as engine development proceeded, problems appeared. The 589 engine was installed only in the test chassis and the first prototype.[citation needed]
      The final car was only 70 in (1524 mm) tall, but was rather large and comfortable inside. Tremulis' design was called the most aerodynamic in the world, and though it still sported pre-war type fenders, it was startlingly modern. The mathematically-computed drag coefficient was only 0.27, although for the public this figure was rounded up to 0.30.
        I got to see the Turbine car in action at the Mopar Nats in Columbus. Sounded like a large hair dryer!
        1992 BMW 325iC
        1978 Chevrolet Monte Carlo
          That thing had a 589ci flat six? dear god each cylinder displaced almost 100ci (1.61 liters)
          1989 cirrisblau-metallic 325i
            Originally posted by ACMF74 View Post
            http://en.wikipedia.org/wiki/1948_Tucker_Sedan
            I've never seen this car before, it is very, very cool.
            John F. Kennedy
              Imagine sitting in a line of turbine cars at a stoplight on a nice hot day...maybe in a convertible
                IIRC, AMC in the 70's put a turbine in a Hornet. But i think it was a one off unlike the Chrysler Turbine car that they made so many of and had the public test them. Then took them back and crushed most of them.
                1992 BMW 325iC
                  The 1959 Austin 7 (aka the Mini):
                  The first successful transversely-mounted-engine front-wheel-drive car...
                  Originally posted by wikipedia
                  The Mini is a small car that was produced by the British Motor Corporation (BMC) and its successors from 1959 until 2000. The original is considered an icon of the 1960s,[3][4][5] and its space-saving front-wheel-drive layout (that allowed 80% of the area of the car's floorpan to be used for passengers and luggage) influenced a generation of car-makers.[6] The vehicle is in some ways considered the British equivalent to its German contemporary, the Volkswagen Beetle, which enjoyed similar popularity in North America. In 1999 the Mini was voted the second most influential car of the 20th Century, behind the Ford Model T.
                  1984 Hennarot 325e - 1990 Brillantrot M3 - 1938 Buick Special Business Coupe
                    From cars to motorcycles, Jalopnik is your go-to site covering everything with an engine—including automotive news, buying guides, and expert commentary from our staff.
                      Renault 5 Maxi Turbo:
                      Driven by Jean Ragnotti:
                      1987 Mercedes 190E 2.3-16: Vintage Racer
                      2010 BMW (E90) 335xi sedan: Grocery Getter
                        Audi Sport Quattro S1 (all you Gruppe-B nuts can eat your heart out...)
                          My favorite car of all time is the BRM V16 Formula 1 car ,, made in the late 40s and early 50s
                          1.5L supercharged V16 115° engine producing 600 BHP @12.000 rpm an unbeaten record for output per Liter for 30 years,,
                          a total masterpiece of engineering,, but the engine suffered with reliabuility
                          GIRLING disc brakes ,, gas shocks and so on .. the power was phenomenal ,, and the car was making more tire-smoke than any machine can make on a rock concert,,,
                          If you are interested on this car you can search the net and get all the info
                          but the greatest thrill of this magnificent masterpiece was the vocal of the engine
                          Herbert von Karajan ,, Luciano Pavarotti and all the others would have been shame to try to beet the wonderful music this engine made .. and nota bene just one and a half liter
                          there should be better 7 min long soundclip .. but i couldnt find it ,, that includes also one lap inside the car
                          turn the volume at the highest peak as possible and kick everybody out of the house
                          Sveinbjörn Hrafnsson
                          E30 CABRIO V12 M70B50 ///
                          ALPINA B10 BITURBO 346 @ 507
                          E34 550 V12 JML
                          Finnish wisdom : If you want to Win,, hire a Finn
                          http://alpina.123.is/pictures/
                            I think the original intent of this thread is heading the wrong direction???
                            1992 BMW 325iC
