where does this plug into?
  • e34john
    • Apr 2006
    • 3599
    Was putting my cluster back in, maybe I am tired but I could not find where this plugs into.
    I plugged everything else in and it seems like everything is working and lighting up but where the hell does that go?
  • Simon S
    • Oct 2004
    • 3758
    Aside from the obvious white/blue/yellow connectors - there are two 'light bulb' wires.
    Only remaining thing would the speed sensor wire.
    Here's a shot I took when retrofitting cruise into a late model:
    Your pic is a little fuzzy - but I think that's what you're holding (speed sensor wire). It should connect to the 'A' slot of a green connector on the back of the cluster.
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • e34john
      • Apr 2006
      • 3599
      I think your right, I got those 3 big wire bundles and the 2 bulbs. The plug I was holding did look like it went into one of those 3 green slots but it didn't look exact so I didn't try it. Damn now I have to take it all apart again.
      • Mossman
        • Apr 2006
        • 1961
        it also doesn't matter which slot you plug it into, if it fits it's a speed signal port
